Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Dodge Ram Decals
Old 01-24-2014, 08:28 PM
The Crow 1994's Avatar
The Crow 1994 The Crow 1994 is offline
Vehicle: 2013 1500 Big Horn Crew 4x4
Trim Level: Hemi 5.7L w/8 Speed
Color: Copperhead Pearlcoat
Rep:56
The Crow 1994 will become famous soon enough
Originally Posted by Adanac Ram View Post
It's a Borg-Warner 44-44 unit and is apparently only available behind the Hemi.
I think that was true about the 2013's, but not so with the 2014's. Check out the photos of this truck. It clearly shows the 3.6L engine under the hood and then shows the 4WD Auto under the gear selector dial.
http://www.landers.com/detail-2014-r...-11326744.html
Mod List: Line-X Platinum Spray-On Bedliner, BakFlip VP Tonneau Cover, TufTruck 1223-V HD Coil Springs, Bilstein 4600 Shocks, Air Lift 1000 Air Bags, Air Lift Wireless One Remote System with On-board Compressor, & Weathertech Digital Fit Floor Liners
Old 01-24-2014, 08:48 PM
Rep:56
Originally Posted by duder888 View Post
The only reason I dug so deep on the subject was because I definitely wanted it on my truck. I thought if I am ordering a new truck I want it to have exactly what I want on it. I told my dealership it will be a deal breaker if it doesn't. They guaranteed me it would. We will see when it gets delivered. They told me if it is not exactly as promised I do not have to buy it.
If you don't mind me asking, what dealer are you working with? I'm from Nebraska, too.
Old 01-24-2014, 09:08 PM
Adanac Ram's Avatar
Adanac Ram Adanac Ram is offline
Vehicle: 2014 Ram 4x4 CC
Adanac Ram is on a distinguished road
I'm definitely lost... the options on that shows QUICK ORDER PACKAGE 22Z and it includes 3.6, 8-speed, and Electric Shift On Demand Transfer Case.
2014 Ram Sport 4x4 .. Black, Crew Cab, 5.7, 8 speed, 3.92, LSD, Tow, Comfort
2006 Dodge Charger .. PWR 426, 10.93@125.62, 1.52 60', +700DA
Old 01-24-2014, 09:41 PM
Rep:56
I know. It is baffling. I feel for those who ordered trucks and are not going to get the 4WD Auto, like they thought they would.
Old 01-26-2014, 09:46 PM
sambo32 sambo32 is offline
Vehicle: 2016 Rebel
sambo32 is on a distinguished road
Can someone explain to me when I could use 4W lock and 4W low.
Thank you
Old 01-26-2014, 10:20 PM
Adanac Ram's Avatar
Both in low-traction situations. Not to be used on dry/bare pavement.
Both have the same F/R lock, but Low adds a 2.6X gear reduction to both driveshafts through the transfer case.
You can shift into 4WD Lock at any time. You should be completely stopped before shifting into 4WD Low.
Situations for 4WD Low... off-roading in mud, crossing through deep water, climbing steep hills, towing someone out the mud or ditch, crawling over rocks, hauling a 15,000 pound trailer around the farm, etc.
Old 01-26-2014, 10:53 PM
Vehicle: 2016 Rebel
thank you for explaining
Old 01-26-2014, 10:56 PM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Trim Level: Tradesman w/3.92 LSD
Rep:974
As Adanac Ram said, plus while in 4WD LOW, speeds should not exceed 25mph.
Total Chaos UCA's, Fox 2.0 IFP Coilovers and shocks, TTC-1223V variable rate coil springs.(Mods list)
Old 01-26-2014, 11:04 PM
Vehicle: 2016 Rebel
can you give me an example on when I can use the 4W lock.
Old 01-26-2014, 11:29 PM
Gantman's Avatar
Rep:974
Well it is recommended to use 4WD Lock in loose, slippery conditions such as dirt, mud, sand, or gravel. Some owners manuals recommend speed no higher than 45-55mph when switching from 2WD to 4Lock but as a precaution, I would highly recommend reading your owners manual on their prescribed recommendations and precautions as different manufacturers and models procedures vary from truck system to truck system.
