Old 01-27-2014, 08:27 AM
Adanac Ram's Avatar
Adanac Ram Adanac Ram is offline
Vehicle: 2014 Ram 4x4 CC
Adanac Ram is on a distinguished road
What Gantman said /\ ... plus snow.
2014 Ram Sport 4x4 .. Black, Crew Cab, 5.7, 8 speed, 3.92, LSD, Tow, Comfort
2006 Dodge Charger .. PWR 426, 10.93@125.62, 1.52 60', +700DA
Old 01-27-2014, 10:49 AM
vtron vtron is offline
Vehicle: 2014
Rep:25
vtron is on a distinguished road
Originally Posted by DonT View Post
4W lock is what used to be known as 4 HI. It engages the front axle but does not change the gear ratio in the transfer case. 4W Lo is 4 wheel drive low range. It changes the the transfer case gear ratio from 1:1 down to 2.6:1. This would be for slow travel off road or if you need a lot more power to the tires, like in deep mud. 4W Low is not something you would use on the street.
I used it during the "snow-megeddon" in DC a few years ago. But that was an extreme situation where surface streets were basically off road.
Those were fun trips to work. Basically off roading the entire time and you didn't have to worry about other drivers. Either you had a 4X4 or you were stuck.
Old 01-27-2014, 01:58 PM
DonT DonT is offline
Vehicle: 2015 Ram 3500
Trim Level: Tradesman
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:23
DonT is on a distinguished road
The news readers here are predicting an "ice-megeddon" tomorrow. I may get to try the 4W Auto feature.
2015 Ram 3500 Crew Cab, Long Box Dually 4x4
2014 Ram 2500 Regular Cab, Long Box, 4x4
Old 01-28-2014, 11:59 AM
duder888's Avatar
duder888 duder888 is offline
Vehicle: 2014 RAM 1500
duder888 is on a distinguished road
Originally Posted by The Crow 1994 View Post
If you don't mind me asking, what dealer are you working with? I'm from Nebraska, too.
I am dealing through Woodhouse. Who are you using for your dealership?
Old 02-14-2014, 11:02 AM
Pipdad3000's Avatar
Pipdad3000 Pipdad3000 is offline
Pipdad3000 is on a distinguished road
Default 4W Auto option
im glad I came across this. I've driven with 4lock on dry roads only because the snow is just gone on certain parts of the road and noticed the binding turning in dry parking lots. I hope I havent caused any damage.
Old 02-14-2014, 11:20 AM
The Crow 1994's Avatar
The Crow 1994 The Crow 1994 is offline
Vehicle: 2013 1500 Big Horn Crew 4x4
Trim Level: Hemi 5.7L w/8 Speed
Color: Copperhead Pearlcoat
Rep:56
The Crow 1994 will become famous soon enough
That's where I bought my truck from last year. I ordered a 2013 from them at the beginning of last summer. I had a good experience with them. Hopefully, you'll have a good one, too.
Mod List: Line-X Platinum Spray-On Bedliner, BakFlip VP Tonneau Cover, TufTruck 1223-V HD Coil Springs, Bilstein 4600 Shocks, Air Lift 1000 Air Bags, Air Lift Wireless One Remote System with On-board Compressor, & Weathertech Digital Fit Floor Liners
Old 02-14-2014, 12:29 PM
sackings19 sackings19 is offline
Trim Level: Bighorn
Color: Maximum Steel Metallic
sackings19 is on a distinguished road
I did a little digging on the transfer cases for the 2014 RAM pickups. Here is what I found. The 4WD versions come with one of two Borg-Warner transfer cases, either the 44-45 (part-time 4WD) or the 44-44 (on-demand 4WD). I talked to the people at RAM and they said the on demand transfer case is an option that needs to be ordered. It comes as an option on the big horn.Here is the link to compare models. http://www.ramtrucks.com/model-compa...1413&variation
If you dig even deeper you can find information that conflicts with what you found. Here is what I found in the 2014 brochure. The shift on demand transfer case (4WD AUTO) is standard on Big Horn, and Sport and above. Outdoorsman and all trims below Bighorn come with the shift on the fly transfer cases. I can't answer why some 14' V6 Bighorns don't have the 4WD AUTO option. Maybe it was one of the late availability options.
http://www.ramtrucks.com/assets/pdf/...am_pickups.pdf
Check out pages 14 and 16 of the brochure.
Old 02-14-2014, 12:38 PM
Tupelo Tupelo is offline
Vehicle: 2014?
Trim Level: Laramie CC 4x4
Tupelo is on a distinguished road
Originally Posted by sambo32 View Post
Can someone explain to me when I could use 4W lock and 4W low.
Thank you
I cannot speak to 4W low - but I have a AWD SUV, with a 4W lock option. It basically locks the differential forcing all 4 wheels to turn in synch -> 50/50 split of power, etc. I use it when I am pulling my boat out of the water and that is pretty much it.
The lock on my vehicle will disable automatically once I go over 25. It is meant to be used for short distances - and in a straight line.
Because the diff is locked, binding will happen - particularly when you turn. When turning the inside wheels will be rotating at a different speed than the outside wheels - hence binding because the differential is locked and won't allow that to occur. It sounds awful - smells even worse - and will destroy the diff and/or transfer case.
Old 02-14-2014, 07:54 PM
crabjoe crabjoe is offline
Vehicle: 2014 Ram 3500
Color: Maximum Steel Matallic
Rep:62
crabjoe will become famous soon enough
Hate to tell you this, but when in 4Hi(Lock) or whatever one wants to call it, or 4Lo, you never get power to all 4 wheels; unless you have lockers in the front and rear diff... You do get a 50/50 split in power from front to rear, but not left to right....
Front or rear wheel drive = one tire on the axle getting power.
4WD = 1 front and 1 rear wheel getting power...
A locker, on the axle will get power to both wheels on the axle. A LSD can give you power to both wheels on an axle....
BTW, when you see power shifting from left to right or right to left, it's traction control doing it. They do it by adjust the throttle and applying the brakes. If you apply braking to the side, where the wheel is slipping, the open diff will transfer power to the other side...
That's all folks!!
Old 02-14-2014, 11:55 PM
sambo32 sambo32 is offline
Vehicle: 2014 Ram 1500
Trim Level: Bighorn
sambo32 is on a distinguished road
My 2014 Bighorn does not have 4WD AUTO, but ever Bighorn I see does have the 4WD AUTO. I guess my truck is rare.
