Old 02-15-2014, 10:51 AM
PTCTreeGuy PTCTreeGuy is offline
Vehicle: 2014 Ram 1500
Trim Level: Outdoorsman
Color: True Blue with Black
Rep:34
PTCTreeGuy is on a distinguished road
It looks to me like Outdoorsman CC 6'4 bed have auto while CC 5'7 and QC 6'4 both have the on demand case. That just comes from looking at trucks on lots on online photos from dealers all over the SE, haven't seen anything about it on Ram's page anywhere.
Old 02-15-2014, 11:07 AM
Cleavor Cleavor is offline
Color: Maximum Steel Metallic
Cleavor is on a distinguished road
The Tradesman and Express don't have it, neither does the Outdoorsman. The Big Horn, Sport and Laramie have it.
Old 02-15-2014, 11:25 AM
TJC.geotech TJC.geotech is offline
Vehicle: 2014 Ram 1500 Crew
Color: Granite
Rep:114
TJC.geotech will become famous soon enoughTJC.geotech will become famous soon enough
It comes as part of the luxury package. If you didn't tic that off on the order sheet, you likely wont get the 4 Auto.
Old 02-15-2014, 11:26 AM
Rep:34
The Outdoorsman CC 6'4 DOES have 4w auto option, have seen at least 20 with it in it, but ONLY the CC 6'4. It also drops the V6 option, only can select Hemi and EcoDiesel which I'm guessing is why the auto box is added.
Old 02-15-2014, 01:33 PM
DetroitDodge's Avatar
DetroitDodge DetroitDodge is offline
Vehicle: 2014 Ram 1500 4x4
Trim Level: Limited
DetroitDodge is on a distinguished road
Default 4x4 option code
the options report for my truck w/ 4x4 auto is, DH8S : Elec Shift on Demand Transfer Case. I'm not sure what the part time case code is.
Old 02-16-2014, 12:58 PM
RiverRat1 RiverRat1 is offline
Vehicle: 2014 Dodge Ram 1500 Crew cab
Color: Dark cherry red pearl
RiverRat1 is on a distinguished road
I have it on my big horn I Don't care for it with all the snow in Michigan I have a good testing platform for this truck and it's options 4wd auto I can still loose
Control of truck because it does not send power to the front until your sliding say on
Curvy road then to late your heading for the ditch 4wd lock both drive shafts turn at same ratio or speed Going down same road same spot I was in 4wd auto no issues tracked straight thur Also with the traction control and anti slip rear it's
And new challange on how the truck will react it will
Apply brake to only one tire and you get jolted and forced around I the cab But truck came with that option
Old 02-16-2014, 02:26 PM
ApexCars ApexCars is offline
Vehicle: 2014 Ram 1500 4X4
Color: Maximum steel/silver
Rep:26
ApexCars is on a distinguished road
Originally Posted by RiverRat1 View Post
I have it on my big horn. I Don't care for it. With all the snow in Michigan, I have a good testing platform for this truck and it's options. 4wd auto I can still lose control of the truck because it does not send power to the front until your sliding; say on a curvy road, then its too late, you're heading for the ditch! With 4wd lock both drive shafts turn at the same ratio or speed. Going down the same road at the same spot where I was in 4wd auto I had no issues tracked straight through with 4wd lock turned on. Also with the traction control and anti slip rear it's a new challenge on how the truck will react. It will apply brake to only one tire and you get jolted and forced around in the cab. But the truck came with that option.
Translated for easier reading. I think I figured out what he meant anyway. Apologies if this was not the intended message.
Old 02-16-2014, 03:01 PM
walc's Avatar
walc walc is offline
Vehicle: 2014 Ram 1500 Sport Quad Cab
walc is on a distinguished road
Does he mean that he prefers 4 HIGH/lock to 4 auto?
2014 Ram 1500 Sport, 5.7L Hemi, 4X4, Quad Cab
Old 02-16-2014, 04:20 PM
Color: Granite
Rep:114
You do not want to be in 4 Wheel anything at the limits of adhesion. It makes things allot more complicated if you get into a skid.
Old 02-16-2014, 10:17 PM
Pipdad3000's Avatar
Pipdad3000 Pipdad3000 is offline
Pipdad3000 is on a distinguished road
Default 4W Auto option
its important to know how your truck handles in 4wd lock or auto. if you have the chance have some fun and get to know what helps and what doesnt. I took a corner too hard once and I knew brakes would send me into a skid, throttle was my only option and the power at the front pulled me into the turn and helped me avoid a big mistake. This is why I dont mind when the kids tell their mother I was doing donuts in the parking lot
