2000 RPM Vibration - Page 11 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 07-06-2014, 08:37 AM
Redfour5 Redfour5 is offline
Vehicle: 2013 Ram 1500 5.7 3.92
Trim Level: Outdoorsman
Redfour5 is on a distinguished road
Default ball park
I think you are probably the closest on this lloydjacobson. Experiencing it periodically and noting the cold weather correlation, I'm thinking it is a simple "Harmonic Resonance" with essentially, and unintentionally, the vehicle resonating at that rpm. When everything is warm particularly the rubber parts between metal parts being all soft and squishy relatively speaking, it is dampened. The colder you get, the less squishy (technical term) and the more the vibrations is transmitted to where you can feel it. And due to the nature of a vehicle and rpm moving up and down intrinsically transient unless it is right at the sweet spot for highway driving and this one is close and could be vehicle specific as in mine might not do it, but yours might as the "exact" rpm for each vehicle would not be the same. Try to chase that down as an engineer. Increase highway rpm even just a bit and it might go away along with some mpg. Even changing that harmonic thing might work for only a bit as systems tend to move toward the harmony (for the system, not you) and not away as I remember. This is all just pure speculation.
Wikipedia - "Sympathetic resonance or sympathetic vibration is a harmonic phenomenon wherein a formerly passive string or vibratory body responds to external vibrations to which it has a harmonic likeness."
Originally Posted by lloydjacobson View Post
Hi All,
After re-reading some of the other posts I'm thinking about tossing the idea from the Chrysler Engineer as exhaust drone. I'm going with 2 ideas... Harmonic balancer or transmission vibration. My reasoning is that the vibration is prominent on the steering wheel and gas pedal. Someone said they changed out the harmonic balancer which resolved their issue. Since the harmonic balancer is made of rubber and metal, temperature can easily affect the characteristics and not eliminate certain vibrations that are naturally caused by the engine. OR the vibration is coming from the torque converter and the rubber isolators and dampers are less effective during cold weather.
If the person who changed out there harmonic balancer reads this please reply or send me a private message.
If anyone has more information about the torque convertor please reply or send me a private message.
Lloyd
Old 07-06-2014, 09:09 AM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Trim Level: Tradesman w/3.92 LSD
Rep:999
I would suggest to everyone who is experiencing this vibration to possibly give TransEngineer a message. He is my first choice for driveline questions when it comes to our Rams, whether 45, 545, 65, or 8HP70's.
Total Chaos UCA's, Fox 2.0 IFP Coilovers and shocks, TTC-1223V variable rate coil springs.(Mods list)
Old 07-24-2014, 07:21 PM
14bluelaramie 14bluelaramie is offline
Vehicle: 2014 ram 1500
Trim Level: laramie
Color: blue streak pearl
14bluelaramie is on a distinguished road
i had the 2000 rpm vibration when i bought my truck feb 1st. it lasted til it got warm and now is not as pronounced. but we still have some cold mornings in Pittsburgh area and i can feel that the 2000 rpm vibration is there just waiting for the cold weather to bother the grap out of me.
Old 07-24-2014, 10:59 PM
Tom-G Tom-G is offline
Vehicle: 2013 RAM CC 4X4
Color: Blue
Rep:40
Tom-G is on a distinguished road
Has anyone had their 2,000 RPM vibration fixed? If so, please provide details. Thanks.
Old 07-29-2014, 02:20 PM
RocketFoot's Avatar
RocketFoot RocketFoot is offline
Vehicle: 2013 Dodge Ram
Color: Western Brown Monotone
Rep:78
RocketFoot will become famous soon enough
Mine still does it at all temperatures but right in the 1800-2100 RPM range. Still not a critical issue for me but does get annoying when I think about! LOL
Old 07-29-2014, 07:47 PM
Color: Blue
Rep:40
The Star center had my dealership check the flex plate for a crack and also to make sure the flex plate bolts were properly torqued. Mind were fine so no fix preformed. Still have the 2000 RPM vibration. I'm concerned about it causing internal damage over the long term, so while it is very annoying, Ram needs to find the root cause and provide a fix.
Old 08-24-2014, 09:59 PM
chief502 chief502 is offline
chief502 is on a distinguished road
Default 2000 RPM Vibration
I had the truck in the shop last week and they checked out the 2000 rpm vibration for me also. According to the paperwork my truck received 3 TSB's/updates 18-012-14, 08-010-014 and 08-018-13. These numbers mean nothing to me but I can tell you the truck feels no different around the 2000 rpm area. It's a 2013 Crew cab SB 6-speed with 3:55 LSD with just 6K miles.
Old 09-15-2014, 08:40 PM
Color: Blue
Rep:40
Default 2,000 RPM Vibration - Fixed (mostly!)
Dealership replaced my torque converter last week. Significantly reduced the 2,000 rpm vibration. It still occurs under certain conditions, but the intensity is greatly reduced. I'll let the new TC break in for about 1,000 miles and will then provide an update.
Old 09-16-2014, 04:39 PM
The Crow 1994's Avatar
The Crow 1994 The Crow 1994 is offline
Vehicle: 2013 1500 Big Horn Crew 4x4
Trim Level: Hemi 5.7L w/8 Speed
Color: Copperhead Pearlcoat
Rep:56
The Crow 1994 will become famous soon enough
Thanks for the info, Tom. Looking forward to reading your update down the road to see if this is something that can have a prolonged affect on limiting the vibration. I have had the vibration on my truck since day 1 and am going to bring it to the attention to my dealer during the next oil change (about 5,000 miles from now).
Mod List: Line-X Platinum Spray-On Bedliner, BakFlip VP Tonneau Cover, TufTruck 1223-V HD Coil Springs, Bilstein 4600 Shocks, Air Lift 1000 Air Bags, Air Lift Wireless One Remote System with On-board Compressor, & Weathertech Digital Fit Floor Liners
Old 09-23-2014, 05:14 PM
maldak maldak is offline
Vehicle: 2014 RAM 1500
Color: Max Steel Metallic
maldak is on a distinguished road
I have a 2014 RAM 1500 with the V6 Pentastar and I have this vibration at 2000rpm as well. I only have 829 miles on the truck and it seems now to be getting really annoying. I do feel it in the wheel and pedal. I'm going to call my dealer tomorrow and see what they have to say. I don't think I felt this when I had less than 450 miles - but I sure do now.
Tom
