Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 01-24-2014, 03:40 AM
Kelevra's Avatar
Kelevra Kelevra is offline
Vehicle: 2012 Dodge Ram
Rep:91
Kelevra will become famous soon enough
Default cold start engine noise
Today was the second time I heard this noise, at first I thought it was a fluke being that it happened when I started it up during the first cold-snap since I owned her and it didn't happen again after that one time. But, today after work, I got in and started it it sounded like a bad knock it lasts for maybe 5-10 secs or so and then it disappeared. It's almost like piston slap but it doesn't happen all the time. It's really starting to worry me. I just went outside to start her up hoping I could get a recording and nothing. purred like a kitten. Should I worry about it or dismiss it because cold engine = weird noises or should I have the dealer look into it?
the problem is that it RARELY happens. this is the 2nd time with all this cold weather that it has done this so I doubt I could repeat the problem if I took it in
Old 01-24-2014, 11:48 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:762
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
how long was is sitting in the cold, vs the other times you tried to start and not heard the noise?
Old 01-24-2014, 05:34 PM
GrayhemiST GrayhemiST is offline
Vehicle: 2012 Ram Hemi Regular Cab
Color: Mineral Gray
Rep:277
GrayhemiST is a jewel in the roughGrayhemiST is a jewel in the roughGrayhemiST is a jewel in the rough
Mine does it on every start up....just louder when it is 0 degrees out! It's the ever so famous hemi knock....I use synthetic oil too!
Old 01-24-2014, 10:46 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
Anything below 25 mine does same thing. Changed to Mobil1 0W20/Royal Purple oil filter. Helps but still makes the gehknock-gehknock-gehknock noise.
I start it up, put it in neutral, turn heat on and let it run for 10mins before I go to work in the morning. Noise is almost gone when I drive away.
Nature of the Hemi beast. Don't really like it, but it is what it is.
2016 Challenger R/T Hemi 6-speed.
2012 Equinox 2.4...Wife's Ride
2014 RAM 3.6/8 speed/3.55 gears........Gone.
"Life's hard, it's harder if your stupid."
How would you know?
Old 01-26-2014, 11:12 AM
MisterGDRam's Avatar
MisterGDRam MisterGDRam is offline
Vehicle: 2012 Ram 1500 Hemi
Rep:28
MisterGDRam is on a distinguished road
Can you post video?
2012 Ram 1500 Hemi Big Horn Edition
Billet Catch Can;Beg Rug Bed Liner
Old 01-26-2014, 03:28 PM
Cheapstreetduster Cheapstreetduster is offline
Vehicle: 2012
Trim Level: ?
Color: ?
Cheapstreetduster is on a distinguished road
i was told at my dealer that its the rear 8 MDS lifters...they are not fully pumped up..and make noise when it first starts...?
2012 st 2500 4x4 4dr longbed hemi 2012 slt 2500 4x4 diesel longbed 2005 slt 4dr 4x4 diesel
Old 01-26-2014, 09:33 PM
oldhp's Avatar
Color: WHITE
Rep:902
I don't believe what the dealer says on that. Anything above 40 mine starts up with no odd/knocking/ticking noise's what so ever. I'm positive mine is the ol'Hemi piston slap.
How would you know?
Old 01-26-2014, 09:41 PM
Color: Mineral Gray
Rep:277
My 05 hemi did it as well.....no MDS....don't know what the dealer is talking about
Old 01-27-2014, 12:57 AM
Kelevra's Avatar
Rep:91
it would make some sense that it's a lifter not being pumped up all the way on start-up. it only lasts 15-20 secs TOPS and that's stretching it before there's no trace of the sound
Old 01-27-2014, 02:22 AM
oldhp's Avatar
Color: WHITE
Rep:902
The MDS shuts off cylinders 1,4,6,7. I agree if at start up there is ticking and 10sec later noise goes away, its the lifters. I would try a different oil filter. Maybe yours has defective ADBV and not holding oil up in the oil galleys.
How would you know?
