Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 01-24-2014, 10:59 AM
GVONAKIS5 GVONAKIS5 is offline
Vehicle: 1988 dodge ram d100
Color: red
Engine: 1988-1991 239ci (3.9L) LA V6 125hp
GVONAKIS5 is on a distinguished road
Default 1988 d100 transmission swap
i need to know if i can put a 1990 a500 overdrive transmission into a 1988 d100. are the mounts the same?
Old 01-24-2014, 02:39 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
The mount points are the same. The OD units have a rear mount extended so that it fit the existing truck mount points, while taking up the additional length and fitting the existing transmission mount points. It's a simple bolt in swap. You will also need a driveshaft about 4 inches shorter. You will also need to provide 12V power to the transmission to activate the overdrive and lock up the converter. A simple single toggle switch will accomplish this. You can leavve the switch on and the transmission will shift into OD shortly after 3rd gear, and the converter will lock up right after OD goes in. It can get tedious flipping that switch if you're in a situation where OD + lockup is too much for the speed you're going. Where 3rd gear is ideal, you have to turn the OD power off. A more "automatic" method will accomplish this at some cost. Go here:
http://www.transmissioncenter.net/dodge.htm
Scroll down to Dodge 518 conversion. It's gonna be the same deal for the 500.
Your mechanical linkage will swap directly.
