Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Ram Vans
Dodge Ram Vans For discussion of Dodge Ram Vans. Please use our existing technical areas for driveline discussion, etc.
ZDOG
Old 01-24-2014, 10:00 PM
scprintz scprintz is offline
Vehicle: 2000 Dodge Ram
Trim Level: B2500
scprintz is on a distinguished road
Default Torque Converter Not Seating
I have a 2000 Dodge with a 46RE transmission. I'm completing a rebuild and attempting to get the torque converter (TC) to seat. I've watch A LOT of videos on seating the TC...been spinning, lifting, pushing, clock & counter, etc. Also tried standing the trans upright and spinning the TC. Ive checked the thrust bearing in the OD to ensure it's installed correctly, I've made sure the frictions in the rear/front clutch are not hung up. (I did add an extra friction and steel to both the front & rear clutches) When I place a straight edge (SE) over the bellhousing, my TC bolting lugs are only 1/16" from the SE. When I place the SE over the bell housing with the TC out, it measures 9/16" to the tip of the input shaft. (is that adequate?) How can I get the TC about 1/2" further down in the bellhousing? Any good ideas are much appreciated!!!
