Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 01-26-2014, 12:56 PM
smithc7589 smithc7589 is offline
Vehicle: 2010 dodge ram
Trim Level: trx4
smithc7589 is on a distinguished road
Question 2010 dodge ram 1500 trx4 no brake pressure
I replaced 3 out of 4 calipers and the master Cylinder bled them until the fluid shot across to the other tire if I pump it up 4 times I have pressure at that time but if I start moving I loose it again. If I disconnect the vacuum hose I have pressure but ever since I change the calipers I havent had the same pressure how do I fix it?
Old 01-26-2014, 10:48 PM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Are you losing fluid when you lose pressure?
