heater/ water pump/ temp gauge - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 01-26-2014, 02:39 PM
Jar33 Jar33 is offline
Vehicle: 2002 ram 1500 5.9
Trim Level: Slt
Color: Dark blue
Jar33 is on a distinguished road
Default heater/ water pump/ temp gauge
Well on friday the 24 my water pump went completely out on my 2002 ram 1500. slt 4x4 w/ a 360. got in changed out with a brand new one. Afterwards the temp gauge went way hot quick then down to just above cold. Then I had no heat at all. Next day I changed out the thermostat. ( yes correctly) still no change. I got the air out of the heater core which gave me very little heat on low. but still no change on temp gauge. All radiator lines get very hot except the inlet line at the bottom. I drove it on the highway for 45 minutes and I could still open the cap and put my finger in the radiator. THE DAMN ANTIFREEZE WAS STILL COLD. Come on RAM ers. Help me. Its 60 today, but 23 tomorrow. I need heat and it fixed right
Old 01-26-2014, 10:42 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Did you get the belt on the water pump going the correct way?
Old 02-03-2014, 07:53 PM
spockmckoy spockmckoy is offline
Vehicle: 2002 2500 ram
Trim Level: LT
Color: almond
Rep:19
spockmckoy is on a distinguished road
Default changed water pump
I just finished changing my water pump this weekend since the weather allowed it. Are you sure your pump is working? Mine had the same symptoms before I changed mine, cold antifreeze, rad cap could be removed, etc. I changed my tstat, cross over/bypass hose, rad cap. I have a 5.9 L gas and refilled with just under 2 gallons of antifreeze/water 50/50 mix. Stupid question, along with the belt question, when you put the fan blade back on? (front toward the front and not reversed?), you installed it correctly? Did you use too much RTV sealant and it leaked into the pump? just some thoughts. good luck.
