Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Old 01-28-2014, 11:19 AM
joostan's Avatar
joostan joostan is offline
Vehicle: 2012 Ram Big Horn
Color: Mineral Gray
joostan is on a distinguished road
I'm sure the dealer would try to void the warranty from doing this. But adding the wires in parallel makes it pretty easy to remove if need be. I can't think of any other reason not to try this
Keep calm and RAM on
Old 01-28-2014, 11:32 AM
ramman2012 ramman2012 is offline
Vehicle: 2012 Ram Sport Crew Cab ST
Rep:17
ramman2012 is on a distinguished road
I already had the 6 gauge RED wire you see and built my own custom lengths. The 6 gauge from the alternator output to battery is the black wire that follows the stock harness from Alternator to fuse box. If I had to do it again, I would just by the black or red 4 or 6 gauge pre built battery cables. This way you can cut them to Size and only have to put ends on one end (and get two cables out of it) as they come pre terminated with nice connectors. You can get 2' , 4', 6' lengths pre assembled at Walmart, Auto Zone etc. To keep it clean and neat and not obvious I used custom lengths. Again, you are not replacing cables, your doubling down on them which fit without issue and keep the install simple. The dual "bolt" heavy duty battery posts are from Auto Zone as well. I had not yet mentioned the stock battery posts here either. What a joke....."el cheapo" stock from dodge. I often wonder if dodge is making the Express series trucks on the cheap?? I would guess the ram diesel 2500's may not have some of the cost reductions the Gas trucks have? I'll have to pop a hood and look at the diesel wiring next time I'm in the dealership. All in all a very inexpensive update that has impressed me thus far as previously mentioned. If your not comfortable with the work, you can have any reputable car Audio shop perform the upgrade. Just mention the BIG THREE electrical upgrade. Note: I see BIG THREE around here is also used to describe and air intake, exhaust, and chip change of sorts as well.
Good day....
PJ
Old 01-28-2014, 11:48 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile
Good day....
PJ
Thanks this is some very useful information. I must do an inspection now. You are correct that this is an easy mod with perhaps some impressive benefits.
Old 01-28-2014, 12:03 PM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
Until you average over time, the initial MPG increase means nothing. I'm guessing it's from the ecu reset, and not the "big 3".
Old 01-28-2014, 12:25 PM
finn5033's Avatar
finn5033 finn5033 is offline
Vehicle: 2014 Ram 1500 cc 4x4
Color: Granite
Rep:32
finn5033 is on a distinguished road
I agree this is very interesting. Even if it doesn't improve mpg, the extra power to the lights, stereo etc would be nice.
Old 01-28-2014, 12:27 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Interesting something new to look at
Old 01-28-2014, 12:52 PM
Rep:17
All,
I'm done with this thread. Take it for what it's worth. No, I've had previous resets as I have upgraded my radio gear several times over the last year and always disconnect the battery for long periods. Correct, at a minimum quicker starts, brighter head lamps, and I'd bet a better charging circuit. If some others try this out...come back and post your experience. I am only one I suppose, but have had noticeable experience in this change and was the driving reason in sharing.
Over and out....
PJ
Old 01-28-2014, 02:17 PM
ncgrl1 ncgrl1 is offline
Vehicle: 2012 Ram 1500
ncgrl1 is on a distinguished road
Thanks Ramman...Very interesting thread!
2012 Ram 1500 Express 4x2
Old 01-28-2014, 05:22 PM
Red-Stripe Red-Stripe is offline
Vehicle: 2012 ram
Rep:117
Red-Stripe will become famous soon enoughRed-Stripe will become famous soon enough
No one has doubted you have seen better mpg #'s. A few of us have only suggested the cause may be from a change of voltage to all/some of the emission sensors, and not from a hotter spark. Cat O2, air temp sensors... etc would all be possible engine control areas that might take some time to re-adjust to a different voltage. The engine may be temporarily operating more lean than usual.
I've experienced ignition modules with 10.5 volt internal regulation. Race guys have bought special high voltage batteries and raised their alternator regulator voltage, then been dissapointed they didn't make more engine HP. If only they knew their ignition module was regulated at 10.5 volts....
Old 01-28-2014, 07:00 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i know nothing about electronics, but could someone explain how this could increase mpg? tks all
