Old 01-27-2014, 05:06 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
Default second battery?
im currently starting to order the components for my new stereo setup. im considering adding a second battery, well more specifically a kenetik back close to the amp.also going do do the big 3 with 0 ga as well the amp kit im gonna run is 0 ga as well. not sure on the amps yet but in the neighborhood of 1000-1200 rms, most i look at seem to be between 100-120 amp between a pair. so would i benefit from a second battery? its small enough to fit anywhere really so thats no issue.
2011 Hemi RCSB Sport 4x4
Old 01-27-2014, 06:31 PM
autokraftgt autokraftgt is offline
Vehicle: 2011 2500
Trim Level: big horn
Color: grey
Rep:31
autokraftgt is on a distinguished road
If your electrical system is running as good, no need for a second battery.
Iam running well over twice the power you will be and have yet to do the big 3 and I have a constant 14.4+ volts.
save your money
Old 01-27-2014, 07:03 PM
I push the skinny pedal
Rep:3298
If you want to run your system longer with the key off then get a second battery. That's all a battery is, reserve capacity. I am installing a second battery because I want to isolate all my accessories and stereo from the main starting battery. The stock charging system will handle the system you're talking about, it's just how long you want to be able to run it before needing to recharge the system.
Kurtis
Old 01-27-2014, 07:13 PM
Vehicle: 2011 2500
Color: grey
Rep:31
I didn't think of that^^^ good point!
I never run my system with the motor turned off so I never thought about that
Old 01-28-2014, 04:59 AM
Vehicle: 2011 Ram
Rep:141
ok awesome more money for other stuff haha ... any opinions on knukonceptz wires? its either gonna be them or cadence
