Old 01-27-2014, 07:19 PM
BowHunter11's Avatar
BowHunter11 BowHunter11 is offline
Vehicle: 2004 Dodge Ram 2500
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft
Rep:63
BowHunter11 will become famous soon enough
Default Help with my 95 Neon
Not sure if this is the most proper place for this post, but here it goes.
I have a 1995 Plymouth Neon, bought it 2 years ago in March with about 60,000 original miles, and I'm the second owner. It was purchased for my girlfriend to drive and hasn't had too many problems for a car of its age. We've replaced the struts, the A/C condenser, and a few other minor things. Recently, its been having some issues and a mechanic at my local Dodge dealership can't seem to figure out what's wrong, as it is still having issues.
After driving the car for a little bit, maybe 10-15 minutes, the problem starts. Whenever you're actually driving, you don't notice it. But when you pull up to a stop sign or stop light, or anywhere to stop, while still in drive, the car seems like it has incredible power and tries to pull away even though I am standing on the brakes. Then once you put the car in park, it begins to rev up real high, then idle back down, then rev up again, then idle back down again. It will do that until you starting driving again or shut the car off. But if you just drive across town, say only a couple minutes, it doesn't do this. Only when the car seems to be warmed up enough. That's just my thoughts.
The mechanic at my local Dodge dealership told me it was the timing belt. So he replaced that and also the idler arm, I think, and said it was fixed. But after driving it approximately seven miles down the road, it was doing it again. So then he fixed part of the vaccum hose, not sure what that is, but he said that should fix the problem. But it is still revving up and idling down when at a stop.
Does anyone have any clue what might be the problem or how to fix it? My girlfriend recently purchased her own car, so I plan to use this Neon to commute to college every day, if I can get it fixed pretty cheap. Thanks in advance for any help given!
Rough Country - Rancho - Nfab - 305/55 Dick Cepek Fun Country - 20x10 XD Diesel - Smarty - K&N - Air Dog - 4" Straight Pipe to 6" Tip - Turbo Silencer Ring MIA - Husky Liners - Kenwood - Spyder Lights - 30" Curved LED - Truxedo - Bushwacker Pocket Flares
Old 01-27-2014, 10:45 PM
relic's Avatar
relic relic is offline
Vehicle: 2014 Laramie CC
Rep:87
relic will become famous soon enough
Sounds like a throttle position sensor
2014 Ram Laramie CC- 22" Maggie, Volant, catchcan, Diablo w/Hemi-Fever, RCX grill, color-matched bumpers, Wet-okole seat covers, debadged
1989 Dodge Omni, 1989 Chrysler Lebaron Convertible
Old 02-17-2014, 06:38 PM
Rep:63
Sorry it took so long but thanks for the advice relic.
I finally had a guy look at the car and he said the same thing. So he replaced the throttle sensor, but it is doing the same thing. He said it may be the map sensor, but that's just a guess; he's a diesel mechanic so he's not certain. And I don't want to spend $300, for just the part, on one guy's guess. Any other ideas anyone?
Old 02-18-2014, 01:50 PM
wolfman01 wolfman01 is offline
Vehicle: 2013 Ram 1500 QC 4x4
Trim Level: Bighorn Edition
Rep:126
wolfman01 will become famous soon enoughwolfman01 will become famous soon enough
Instead of throwing random parts at the car, I would get values for the operational ranges of the sensors, and hook up an OBD computer to the car if one can, that shows live data as it's being driven. Once the car starts to act up, look at which sensor is going offline. I would start running the wiring loom beginning where that sensor is installed. A 20 year old car with 60k miles on it has very likely been the subject of curiosity by rodents at some point in it's extended period of sitting around. Barring that, look for corroded grounds. Intermittent issues like this are typically not caused by a part failure.
If no OBD, then you have to use a good volt/ohm meter and look at the values the hard way.
2014 Chevy Spark (3k)
2013 Ram 1500 Quad Cab 4x4 Hemi 8 speed (7k)
2004 Saturn ION Redline (9k)
1995 Tiffin Allegro Bay (46k)
1989 Oldsmobile Cutlass Cierra (97k)
Old 02-18-2014, 02:17 PM
Rep:63
I don't have access to something like an OBD computer, although that would be nice. On the other hand, my dad has a volt meter he uses for working on pumps for people's houses. I don't know much at all about mechanics or electrical issues, so what/how do you mean looking at values the hard way?
Old 02-19-2014, 01:51 PM
Rep:126
What you need to get are the voltage ranges that the sensors operate in. You want to look for voltages that are outside the operational range of the sensor, most likely reading zero. When the car is running right, all of the sensors should be showing their voltages in their proper range. The one that doesn't show the proper voltage range (may toggle if it cycles), or shows wild numbers will be the one that is causing your issue. As others have mentioned, even though your TPS has been replaced, I would still suspect that circuit, or mass airflow sensor and its circuit. The car is apparently having issues knowing how much fuel to inject, causing your screwy idle. The time span you are discussing is proper for when the car changes from "open loop" (no sensors to dictate air/fuel mixtures) to "closed loop" (sensors determine quantity and duration of injection).
This is why electrical issues get expensive fast. They are a bitch to troubleshoot.
I would also clean that throttle body to make sure that being carboned up isn't the cause of your issue.
