Overheating and skipping - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-31-2014, 03:04 PM
jakem49's Avatar
jakem49 jakem49 is offline
Vehicle: 1999 dodge ram 4x4
Color: red
jakem49 is on a distinguished road
Default Overheating and skipping
I have a 99 dodge ram 5.9 with 249,000 miles it has been overheating so I replaced the water pump the t-stat the heater core and the radiator this fixed the problem for 2 days now it overheates to about 245 for about a minute then it goes back down. Also right before i did all the work it started skipping when I first start it up and will skip for about 2 minutes when I drive it. I did a full tune up about 10,000 miles ago anybody have a clue what this could be? Any feedback is greatly appreciated
if you cant dodge it, RAM IT!!!!!
Old 01-31-2014, 05:35 PM
omarimoe omarimoe is offline
Vehicle: 1997 Dodge ram 1500 SLT
Trim Level: SLT Laramie
Color: silver
Rep:21
omarimoe is on a distinguished road
fan clutch engaging? bleed all the air from the cooling system? plug wires routed correctly? thermostat opening and closing properly (could be lazy)? id start with some of those and see what u get.
Old 02-01-2014, 12:09 AM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
The temp thing sounds like air still in the system. I have heard many ways to bleed it, but none I can say I've tried. Some have said to park the truck at an incline, with cap off. Start, and fill as needed til the fluid starts to come out, then cap. Make sure the overflow container has fluid in it. The cap will allow excess pressure out. The key is to have a good radiator cap. Use a pressure tester on it. A bad cap will screw this all up. After shut-down, the system should vacuum fluid from the overflow as it cools.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 02-02-2014, 07:27 PM
jakem49's Avatar
Color: red
thanks guys I bled the air and its quit overheating for now. the skipping was a cylinder 8 misfire.the sparkpug was burnt up, so I changed it, and it still skips a little but no more code.......off to try to fix thst now
