Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 01-28-2014, 05:11 PM
Getnoff Getnoff is offline
Vehicle: 1999 Rame2500 Diesel
Trim Level: Quad Cab
Color: white/silver
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
Getnoff is on a distinguished road
Default '99 RAM 2500 Diesel Towing Capacity
New to the forum, so I hope I'm in the right location to ask this question...
I have a '99 RAM 2500 5.9 Cummins Diesel long beg Quad Cab SLT 2-wheel drive automatic trans. The drivers side rear door was damaged years ago in an accident and the "info plate" that should be there is no longer present. I assume the door was totally replaced in the repair. In any case, I need to find out what the towing capacity of my vehicle is as I'm buying a new 5th Wheel RV. How can I find out the gear ratio, GVWR, maximum trailer weight capability, etc.? Can anyone help me here? Please let me know.
Thank you!
Pete
Old 01-28-2014, 06:59 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
I think you'll want to upgrade the Cummins for more hp after driving a friends 2001 with the 24 valve. I'm a great Cummins fan and the 2500 should be fine with the load, just underpowered. I tow a 10,000 lb 32' Coachman fifth wheel with my 1500 hemi pretty easily and have towed a similar size trailer with the 01 Cummins Ram and it was much easier with the hemi. I don't think it would take much, better exhaust, a tuner maybe. Perhaps your Dodge dealer can look up your serial number and find out more info on your Ram.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 01-28-2014, 08:29 PM
Color: white/silver
I forgot to mention that my truck does have a Banks Kit on it. I'd have to get the paperwork out to specifically detail which Banks Kit was installed. At that time Banks offered 3 upgrade kits for my particular vehicle, and I chose the mid-upgrade which did include an all new exhaust system.
Old 02-04-2014, 01:15 AM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Your truck must have been revving pretty high. You were also over towing capacity. Sorry, but I don't buy it. I've had Hemi trucks as company trucks. There's a reason I own a Cummins.
24v trucks aren't the fastest stock, but hook a trailer to them and that's where they really shine.
You most likely have 3.55 gears. What are your RPM's at 70 mph? And what size tires do you have?
Check this out:
http://dodgeram.info/2001/towing-charts.html
It's for 2001, but nothing major changed from 99 to 01.
