Need electrical help!!!! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 01-30-2014, 02:54 AM
Carmasdad Carmasdad is offline
Vehicle: 2013 dodge ram 1500 crew cab
Carmasdad is on a distinguished road
Default Need electrical help!!!!
I have a 2013 bighorn crew cab my drivers door controls won't adjust the mirrors or roll down the front driver or pass window but it will roll down the back ones. The switch on the front pass door works fine. I've checked fuse 24 I think which is the driver door control module fuse and it's good. It would make more sense if it didn't work at all but it still runs the back doors I'm confused any advice would help a lot thanks
Old 01-30-2014, 03:51 AM
RAM357's Avatar
RAM357 RAM357 is offline
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
Have you pulled the controls to see if any wiring has come loose?
Var
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau* Iron Bull Fr. bumper with custom Line-X coating* Lumens HID low beams
Old 01-30-2014, 04:25 AM
Pulled door panel checked the plug ins on the door control module and checked at the switch a few times all plugged in good and no wires backed out of plug I'm so confused
Old 01-30-2014, 04:11 PM
rdm1465's Avatar
rdm1465 rdm1465 is offline
Vehicle: 2017 Ram Laramie Megacab
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
rdm1465 is on a distinguished road
You could have a bad switch. Anything electrical can go bad at any given time without any indications. Just take it to a dealership service dept and have them fix it. It is still under warranty after all.
Old 01-30-2014, 06:47 PM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
If you're one of the DIY type of people, you could pull the switch, and check the continuity across the non functioning parts of the switch.
Personally I'd just bring it to the dealer, as it's been stated it should be a warranty item.
good luck
Exco
Bill
Old 01-30-2014, 08:46 PM
mastertech10 mastertech10 is offline
Vehicle: 2013 RAM 1500
Rep:12
mastertech10 is on a distinguished road
ok so with the master switch the front windows and mirrors are connected to the drivers door module, and then are controlled by either door module. the rear windows are hardwired from the switch directly to the doors. Anything else happening strangely?
I suspect it is either the switch or the drivers door module. As mentioned above, take it to your dealership and them scan it. likely you will have a loss of communication code with the master window switch or will have codes for drivers door module. I have seen on the 10 and 11's one connector will corrode at the door module.
Old 02-10-2014, 03:27 AM
Any idea on fuses the dealer is about an hour away and my work schedule is awful
Old 02-15-2014, 06:46 PM
RAM357's Avatar
Rep:580
When you pull the controls, can you turn the truck on and puling the leads off the switch for the driver front window, try to open the window by directly touching the leads together to close the circuit?
Following that logic will at least give you a quick and dirty method to bypass the switch(es) so you can rule their involvement in or out. If the switch bypassing doesn't work, then that could point to a control module as stated above, in which case you could always order one and giver 'er a whirl.
Var
