Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
Old 01-30-2014, 08:17 PM
paulssigns paulssigns is offline
Vehicle: 2014 ram 2500
Trim Level: laramie
Color: granite
paulssigns is on a distinguished road
Default lowered air pressure how do i reset the toms
i have a 2014 ram 2500 laramie,lowered the air pressure down to 45 lbs.how do i restet the light without going to the dealer?
Old 01-30-2014, 08:20 PM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Color: Deep Cherry Red
Rep:85
APSTRAM will become famous soon enough
Did you lower all 4 tires? On my 2012 only the rears work with the lower pressure at 45.
Old 01-30-2014, 08:37 PM
Trim Level: laramie
Color: granite
lowered all 4.truck rides much better
Old 01-30-2014, 09:35 PM
comatone1982's Avatar
comatone1982 comatone1982 is offline
Professional meatbag
Vehicle: 2014 Ram 1500
Trim Level: Sport Crew Cab
Rep:34
comatone1982 is on a distinguished road
My tps system says to drive for a few minutes at low speed to auto reset the readings. I dont know if yours would be the same, but considering we both have 2014 models, Id assume they are.
Reflex spray liner // 8% over factory 20% rear tint // Rigid Industries 30" sr lightbar // Weathertech digital cut mats // Billet Industries catch can and engine dress up kit // BFGoodrich All terrain TA/KO 2 tires // Viper remote starter // AntennaX 13" stubby // DeeZee tail gate assist // Mopar SS sill covers
Old 01-30-2014, 09:47 PM
Bushmaster's Avatar
Bushmaster Bushmaster is offline
Trim Level: Outdoorsman 4x4 CC
Color: Bright White Clearcoat
Rep:83
Bushmaster will become famous soon enough
I know I lowered mine to 40lbs in front and 42lbs in rear and I don't have any warning lights. Only time I got a warning light was when air temp dropped to -30 C.
Bakflip G2 tonneau cover, SunTek clear wrap complete front end, Trail FX wheel to wheel nerf bars, Huskyliner mudflaps, Weather Tech front floor mats, rear Recon mini lightbar,20% tint front door windows, 5% tint rear door/rear window, Smittybilt Lightbar with 10" Rigid LED lightbar
Old 01-31-2014, 02:34 AM
deathwarden5 deathwarden5 is offline
Vehicle: 2014 Ram 1500 Sport CC
Trim Level: Crew Sport
Rep:26
deathwarden5 is on a distinguished road
The owners manual explains how to change the TPMS to light load, for RAM 2500 models.
EDIT: Nvm... apparently RAM removed the light load option for 2014 (I was looking at the owners manual for a 2013). Basically there is nothing you can do. The light will be on as long as you are below the recommended pressure.
Old 01-31-2014, 09:48 AM
SRTian's Avatar
SRTian SRTian is offline
Vehicle: 2014 Ram 2500 Crew Cab 4x2
Color: True Blue Pearlcoat
Rep:17
SRTian is on a distinguished road
When I first bought my 2500 I noticed the front and rear were both at 80 psi. I lowered the front to 65 per door sticker and then decided to do the same for the rear. The warning light never came on until some cold weather dropped the rear below 65. I had to air up to 80 again to reset the light.
