Old 01-30-2014, 11:57 PM
omarimoe omarimoe is offline
Vehicle: 1997 Dodge ram 1500 SLT
Trim Level: SLT Laramie
Color: silver
Rep:21
omarimoe is on a distinguished road
Default grill replacement/customization
97 ram 1500 and i cant stand the old faded grey honeycomb like backing in my grill. i originally wanted to remove just the inserts and paint them a gloss black to kind of mimic the sport grill but with the chrome colored outer grill. my problem is it appears that the inserts are plastic welded onto the mounting tabs and the only way to remove them would be to cut the tabs leaving me no way to remount the inserts. has anybody found a way to get them off without cutting them or found a way to remount them after cutting them off?
Old 01-31-2014, 01:16 AM
BigRedRam1500's Avatar
BigRedRam1500 BigRedRam1500 is offline
Vehicle: 2014 Ram 1500
Trim Level: Laramie Longhorn 4x4
Color: Deep Cherry Red & Gold
Rep:58
BigRedRam1500 will become famous soon enough
I've watched a couple you tube videos showing the grill change outs and they use a tool to pry the tabs out without damaging them.
Old 01-31-2014, 10:02 AM
slimpartywagon's Avatar
slimpartywagon slimpartywagon is offline
Vehicle: 1995 Dodge Ram 1500, 2000 Ram
Trim Level: Laramie, SLT
Color: Blue
Rep:95
slimpartywagon will become famous soon enough
another option is masking tape... mask off the chrome you want to keep chrome, and paint away.
Old 01-31-2014, 04:08 PM
Color: silver
Rep:21
i was gonna do that but i really wanted to prep the plastic really well so the new paint dosnt just chip off and look like crap. i figure with it being on the front of the truck at highway speeds sand and rocks and such would probably tear it up pretty good.
Old 02-01-2014, 10:43 AM
Color: Blue
Rep:95
you can still prep ... just tape before you prep, then unmask and remask before you paint
Old 02-01-2014, 11:05 AM
kilrram kilrram is offline
Rep:12
kilrram is on a distinguished road
Have you thought about using plasti-dip? Since the inserts sound like they are a pain to remove, you could do the following:
1. Remove the grille from the truck (to keep overspray off the rest of the truck)
2. Wash thoroughly with soap & water and let dry
3. Spray the grille and inserts with plasti-dip
4. Wait for the plasti-dip to dry (about 4 hours I think)
5. Use a sharp knife and cut the plasti-dip between the inserts and the grille surround
6. Peel the plasti-dip off the grille surround
7. Install the grille back on the truck
8. Enjoy your great looking grille!
I did basically the same to my truck (2013 Ram 1500), but I removed the inserts instead of the spray & trim technique I described above.
Before:
After:
Sean | Check out my build thread HERE
Mods: Front Window Tint 20%, Access TonneauSport cover, Westin Pro Traxx Running Boards, Lund Interceptor Bug Deflector, Blacked-out Flares & Grille Inserts, Line-X Bed Liner, Husky X-act Mats
Old 02-01-2014, 07:42 PM
Docnoisewater's Avatar
Docnoisewater Docnoisewater is offline
Vehicle: 2001 Dodge Ram
Docnoisewater is on a distinguished road
When i painted mine with the truck bed paint i used plastic adhesion promoter and then used bumper and trim paint, came out nice.
Old 02-01-2014, 08:27 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
I like the Plasti-Dip idea! But Doc is also right, using the adhesion promoter after a thorough cleaning, adds alot to the durability of the coating. I used his method for all the faded gray front-bumper-air-dam-trim-crap. It has stayed black and chip-free for a year now.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 02-02-2014, 08:48 AM
Color: silver
Rep:21
thanks for all the ideas guys im going to try and get it done sometime this week ill post some pics along with how i end up doing it when its completed.
Old 04-22-2014, 02:29 AM
Color: silver
Rep:21
so to update (i know like 2 months behind) i ended up hitting a small deer and pretty much destroyed my bumper grill and hood. luckily when i called my local junkyard they had just got a 98 ram, same color and everything but hit from the side. all in all i got hood, grille, bumper, and all the plastics for $250. anyway i was kind of rethinking my grill idea and since i really like the RBP type grills and such i was wondering if anyone here has made something similar? i just cant justify a $700 grill on a 97 ram with 148k on it so i was thinking id try and make one. i was thinking if i cut out the cross sections of the grill i could mold in some diamond cut gutter guards or something. after their molded how i want and fit nice i could hit them with some bedliner for rigidity so they arnt so flexible and they dont look pushed out/in. after the bed liner i could paint them and then re install. anybody do anything similar? any thoughts or problems you guys might foresee with this idea? i am also thinking about tearing off all the faded crap and trying to color match it to the truck with the paint code specific auto zone spray cans. anyone have any experience with that paint? if so did it match well? did it hold up well?
