Old 01-31-2014, 07:49 AM
c taylor c taylor is offline
Vehicle: 2001 dodge ram 2500 4x4
Color: white/ black
c taylor is on a distinguished road
Default Hay Wired
Got this 01 2500 5.9 Mag. 4x4, having a heck of a time with the O/D off light. Start the engine, light comes on and stays on till you press button on shifter. Fan switch has to be on 2nd notch so compressor doesn't cycle. If you switch AC on while running O/D light comes on , it also downshifts if you are at highway speed, if you press brake pedal at highway speed , light comes on and downshifts. Have cleaned all grounds, replaced brake switch, replaced tps... what to do ?
Old 01-31-2014, 03:08 PM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
have you looked at your fuse block to see if something is wrong there? it sounds like several circuits are being crossed. or it could be broken wires in the dash harness.
Old 02-01-2014, 03:51 PM
Color: white/ black
could be under dash, the cover is cracked and the truck was crashed on pass. side at onetime, before me owning it
Old 02-06-2014, 08:46 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
You seem to be looking in the right place. With DC, if it don't work, check power. If it works weird, check grounds. Double-check engine to chassis ground?
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 02-18-2014, 12:35 AM
PostalTwo PostalTwo is offline
Vehicle: 2014 Ram 1500 Crew 4x4
Trim Level: sport
Color: maximum steel metalic
Rep:14
PostalTwo is on a distinguished road
i sound definitely like a ground issue id put money on it if u have the ac off and heat set to vent does it do it?
2014 sport hemi 4x4 with 8speed bone stock max steel metallic and love it!
