Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 > Exhaust
Exhaust 4.7L Exhaust Discussion
Old 02-03-2014, 11:46 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
if the muffler is shorter than the factory muffler none of them will be a direct fit, there are companies out there that take popular mufflers and add the extension pieces and clamps to them so that it becomes a direct fit, but other than that just buying a muffler you will not find a direct fit from the big manufacturers, unless it is a factory replacement muffler which you do not find much of for our Rams
Old 02-03-2014, 12:32 PM
izzy's Avatar
izzy izzy is offline
Vehicle: 2012 Dodge Ram
izzy is on a distinguished road
Thank you Andrew, so much good information on this forum.
Will i have to buy an extra part to make the muffler fit?
Old 02-03-2014, 05:20 PM
Hornet Hornet is offline
Vehicle: 2014 RCSB 8sp/3.21 geared Ram
Trim Level: Sport lowered 4X4
Rep:488
How goods your tool selection.
If you're not well set up on tools,your best bet is probably a muffler shop.
We put a 22" Magnaflow on Audio's truck,and it took the better part of an evening.
In fact i swapped my whole exhaust for a Magnaflow dual set-up in about the same amount of time,as doing just his muffler swap,
Although we did it the hard way,lol.
Andrew can probably set you up with an aftermarket Magnaflow kit though that is a direct bolt-on with all the piping and adapters already installed
Old 02-03-2014, 07:40 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Just beware most muffler shops use mild steel(will rust) and crush bends.
Sean
Old 02-03-2014, 09:08 PM
izzy's Avatar
how does it sound? i haven't thought about a 22" i have been stuck between a 14" and 18" for about 2 months now i don't know which one to get.
Old 02-03-2014, 09:30 PM
snrusnak's Avatar
Rep:1385
Here's a 22" magnaflow dual 2.5" inlet single 3" outlet with no cats and stock resonator/tailpipe. On my 2010 4.7L
http://s1133.photobucket.com/user/sn...tml?sort=3&o=1
Sean
Old 02-03-2014, 11:29 PM
Rep:488
As Seans video can attest to,the 22" on the 4.7's sounds good.
I have the Magnaflow cat back dual set-up on my 13,that uses the 22" muffler,and on the 4.7 they sound really good.
I do have some drone,but that i attribute to being a shortbox regular cab, the pipes are shorter then most,and being a Magnaflow kit,there's no factory resonators either
Old 02-04-2014, 09:26 PM
MIRam2009 MIRam2009 is offline
Vehicle: 2009 Ram 1500
Trim Level: SLT Quad Cab
MIRam2009 is on a distinguished road
Thumbs up
Well, ordered up the 14"...it'll hopefully be installed on Thursday! I'll post a video when I can.
Old 02-05-2014, 10:08 AM
pitcher3853's Avatar
pitcher3853 pitcher3853 is offline
Vehicle: 2009 Ram 1500 TRX4
Trim Level: TRX4
Color: Detinator Yellow
pitcher3853 is on a distinguished road
This is exactly what I'm about to do with my truck and this thread and forum in general have been very helpful! Finally decided on an 18 inch magna flow. I do have one question though... What is the difference between the satin finish and the mirror polish? I realize that it's mainly cosmetic but the satin is still stainless steel right? I like the satin because it is cheaper but I just wanted to double check with you guys. The roads here in Wyoming are always a complete disaster and my truck spends about 60% of its life off road so I want to make sure whatever I get will hold up well. Thanks!
Old 02-05-2014, 06:30 PM
snrusnak's Avatar
Rep:1385
yes still SS just not polished to a mirror finish. purely cosmetic.
Sean
