Decided on offset for rims - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-31-2014, 08:52 PM
boomer135 boomer135 is offline
Vehicle: 2013 Ram
Trim Level: 4X4 CC Sport
Rep:39
boomer135 is on a distinguished road
Default Decided on offset for rims
I have a 2013 CC 4X4 sport. Ill be doing the 5100's maxed out and a 1.5"BL
Tires will be Nitto Trails 35X12.50X20
Rims will be Fuels (undecided type yet)
Should I stay with a 12.50 tire? If so what rim offset?
I searched a lot, and find most are using a -12 or -24 offset.
I would like to see some measurements on how far the tire will be past the fender with either a -12 or -24 offset.
Hope to get all this done soon as I recover from surgery...
MODS: PE Full Metal Jackrabbit, BT Catch can, Magnaflow 18", Vararam, Bullydog Hemi Tuner, Zone 1.5 BL, Bilstein 5100's @2.8, TG 1.5 rear coil Spacers, Fuel 20x10 -12OS, Toyo OC MT 315/60R20, Painted BW Pocket Flares http://www.ramforumz.com/showthread....88#post1344588
Old 01-31-2014, 09:01 PM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
I have +1 offset and my 35"s stick out about 1.25". Nitto Trails are slightly wider due to their aggressive side wall... so add about another .5 for the -12, and another .5 for the -24. Here are some side pics of mine (post#26): http://www.ramforumz.com/showthread.php?t=162904
MODS: Magnaflow Cat-Back Exhaust, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Lund Fender Flares, Aries Stealth Bull Bar, & KC SlimLites.
Old 02-01-2014, 02:36 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:418
What Stang said. Just depends on how far you want them to stick out.
Old 02-01-2014, 02:54 AM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
what was said above^^^ -12mm and -24mm will give you a very aggressive stance.
sales@revelperformance.com
Old 02-01-2014, 03:31 PM
Vehicle: 2013 Ram
Rep:39
DO you have any pictures from the back and front showing how far the tire sticks out away from the fender with your offset? Also read your thread and thanks for the advice for the hub centric inserts, I think those are a must to add!
EDIT: never mind just saw the updated pics on your thread…
Old 02-01-2014, 03:32 PM
Vehicle: 2013 Ram
Rep:39
Just tough decisions, ya know how it is. I emailed you on the pricing for the 5100's and Zone 1.5 BL, haven't heard anything back form ya.
Old 02-01-2014, 04:37 PM
huff73541 huff73541 is offline
Vehicle: 2007 Ram 1500 Big Horn
huff73541 is on a distinguished road
I have 35x12.50-20 Nitto Trails and 20x10 -24mm Fuel Kranks
Stick out about 2.5-3 inches I'm guessing
This is on my 2007...Shouldnt be much difference vs the 4th gen...
I think theres a 1/2" difference between -12mm and -24mm
Hope it helps!!
Old 02-01-2014, 05:57 PM
Vehicle: 2013 Ram
Rep:39
Pictures like that are exactly what I'm looking for. for me I think -24 might be too much, so -12 might be a bit better if it will bring the tire towards the truck another 1/2 inch. Looks great though. I ride my truck in rocky areas and don't want to kick up too much on the exterior of the truck. Flares will be a must with full coverage on the tire to prevent possible exterior damage.
With all the past searching I have done, I can't believe I just found this Post. IT"S A MUST READ! Very detailed, and answered almost every question I had. http://www.ramforumz.com/showthread.php?t=159580
Looks like The Final word is 20x10 Fuels -12 offset with nitto trails 35x12.50x20 5100's maxed with Zone 1.5BL will get the job done. Plus look AWESOME! I'm about a month away from physcially being able to do the install.
Hope it helps!!
Old 02-01-2014, 06:43 PM
Vehicle: 2013 Ram
Rep:39
One more thing to add. When choosing between tires here are the differences between the actual Toyo, and Nitto Measurement:
Toyo: 35X12.50X20 Actual Height:34.50 Actual Width:12.50
Nitto: 35X12.50X20 Actual Height:35.04 Actual Width:13.39
I might have to choose the Toyo as opposed to the Nitto due to the actual tire width.
Old 02-01-2014, 07:46 PM
I do have the pocket flares from bushwacker and they are pretty flush with the tires. They still splash up the side a little but doesnt bounce rocks off the paint...
I wanted the tire to be flush or slightly wider than the flares so I opted for the -24mm for the wide stance and wheel lip...dont really like the look of the flares out past the tires even tho that is there purpose lol...
can't wait to see your truck!!! good luck!!
With flares
