Old 02-03-2014, 07:55 PM
Pathman Pathman is offline
Vehicle: 2012 ram
Trim Level: Outdoorsman
Color: Sage
Pathman is on a distinguished road
Default Lift and tire size ?
Hey all, I have a 1500 Outdoorsman that I'm considering lifting slightly so I can fit the next size tire on it for a little more clearance in the field.
Can anyone tell me how high I'd need to go to fit the next size bigger AT tire on it, what size tire that would be, and if there are any issues associated with lifting?
Thanks
Old 02-03-2014, 08:52 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
Well what do you consider "the next size bigger". You can fit up to 35's with just a level. 37's with a 6" lift. A 285 is typically the widest you can go on the stock wheels without running spacers.
Take a look at the wheel and tire section of the forum or the lifting section. There's some stickied threads in there with a ton of pictures. Just look through those and you'll get a good idea of what you like and what you don't.
Old 02-03-2014, 09:29 PM
Vehicle: 2012 ram
Color: Sage
Thanks BJ, didn't know where to start.
Old 02-03-2014, 09:30 PM
Vehicle: 2012 ram
Color: Sage
35's sound good, but I'm not familiar with the details of a level, can you elaborate?
Old 02-04-2014, 09:52 PM
boomer135 boomer135 is offline
Vehicle: 2013 Ram
Trim Level: 4X4 CC Sport
Rep:39
boomer135 is on a distinguished road
Take some time and read this thread it should explain it all to you.
http://www.ramforumz.com/showthread.php?t=159580
MODS: PE Full Metal Jackrabbit, BT Catch can, Magnaflow 18", Vararam, Bullydog Hemi Tuner, Zone 1.5 BL, Bilstein 5100's @2.8, TG 1.5 rear coil Spacers, Fuel 20x10 -12OS, Toyo OC MT 315/60R20, Painted BW Pocket Flares http://www.ramforumz.com/showthread....88#post1344588
Old 02-05-2014, 12:04 AM
Rep:2032
Yup, take a look at this ^^ thread. I wrote it specifically for guys like you who are unsure about the details of leveling and sizing. If you have any questions after that post them up and I'll answer the best I can.
Old 02-06-2014, 08:03 AM
Vehicle: 2012 ram
Color: Sage
Wow, tremendous effort providing all that info, thanks you!
After reading both posts, and at the risk of sounding like a pain in the arse, do you have a similar post relating to a full lift rather than a level job?
For some reason I'm leaning toward a full lift of 3-4" and then fitting the largest possible BFG A/T's that will fit.
Does Bilstien offer a lift kit? If not, what kit would you reccomend?
Thanks for you patience and efforts.
Old 02-06-2014, 12:38 PM
Rep:2032
No I haven't done anything for a full lift yet. I've thought about it but it almost gets to the point where there's to many variables to sum up in a thread like that. Leveling is more straight forward and there's more demand for that information.
All the stuff regarding tire width and how much they'll stick out etc will apply to a 4" lift as well. Largest you can go with a 4" lift is a 35 or an oversized 35 like a 325/60/20.
No Bilstein doesn't offer a full lift kit but you can run their shocks with a lift. Lots of guys use the Bilsteins to level out a lift since most of them do not fully level a truck by themselves. For 4" lift kits I'd look at BDS or Zone.
Old 02-06-2014, 07:27 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
you can fit a 37x 12.5 in a 4'' lift... can order them from the dealer like this
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
