Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Place your Ad Here!
Old 02-04-2014, 02:38 PM
bartlett bartlett is offline
Vehicle: 2013 Ram quad
Color: gray
Rep:323
bartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the rough
Default Wow 4+4 lock is not lock !
I towed a ram this am and he was just missing a pole so I had him goto 4wd low lock and I would tow him slightly forward and have him give it gas to miss the pole being I could not tow him forward from where he was. So I hooked up and he went to 4wd low lock. I looked back and the rear tires were spinning ! I just told him again to goto low lock. He said it is ! So I looked, it said it was. He gave it alittle gas and the front started spinning. IMO the truck should be locked together and spin one front and one rear unless lsd. Im shocked that this case will not go into lock. Are they all like this ? Mine seems to lock but mine has the older case.
interesting ....
Old 02-04-2014, 09:37 PM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
Without being intimate with the situation my guess is with the electronic selector sometimes takes a few seconds to go between selections. Probably didn't wait long enough. They are not Torsen or viscous coupled
Silence! Differing opinions will not tolerated
Old 02-05-2014, 05:13 AM
TJC.geotech TJC.geotech is offline
Vehicle: 2014 Ram 1500 Crew
Color: Granite
Rep:114
TJC.geotech will become famous soon enoughTJC.geotech will become famous soon enough
With the electronic transfer cases, if you apply too much power during the shift, the computer will refuse the shift. That's why it finally went in when he lifted on the throttle. Also, if the truck is stationary and there is to much pressure on the driveline the gears will not be able to mesh, and again the computer will refuse the shift. Your buddy needs to read his manual.
Old 02-05-2014, 09:11 AM
Color: gray
Rep:323
um no ! you might wanna go look at your truck ...if your transfercase has the auto 4wd option you do NOT have 4wd lock ! you only have AWD ...
if you put your truck in 4wd lock it will not be locked into 4wd ! the front will not be locked.
To test this go out and find a parking lot with ice in it and put the front wheels upto the curb ,goto 4wd low lock (wait for the 4wd lock light to come on) let off the brake and the rear tires will spin (if on ice) and the fronts will not ! if you jump on the gas the front will engage. thats AWD not 4wd lock ...
youve been had ! .....
Old 02-05-2014, 09:20 AM
DonT DonT is offline
Vehicle: 2015 Ram 3500
Trim Level: Tradesman
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:23
DonT is on a distinguished road
That is not the way mine works. If I put it in 4W Lock and wait for the confirmation on the instrument panel I have 4 lock just like all the other 4x4 vehicles I have ever had. If I put it in 4W Auto it work as you describe. I think in the OP the other driver did not allow the transfer case to actually get into 4 lock as TCJ suggested.
2015 Ram 3500 Crew Cab, Long Box Dually 4x4
2014 Ram 2500 Regular Cab, Long Box, 4x4
Old 02-05-2014, 09:31 AM
Color: gray
Rep:323
before you say yours dont do that go out and test it ..... the only time the case will engage 4wd is when the gas is pressed ..thats awd not 4wd lock ..
Note this is not the standard 4wd case. that case will do 4wd lock.
Old 02-05-2014, 09:38 AM
Color: gray
Rep:323
while searching for info on this , I found this !
Ha Im not the only one who understands this problem ....
ww w .ram forum .com /f38/4x4_problem_ram_2013_8-speed-40753/ ((((****put the link back together****)))
Old 02-05-2014, 10:51 AM
battlerattle's Avatar
Vehicle: 2016 Ram 2500 Laramie LongHorn
Trim Level: Laramie LongHorn
Color: Granite
Rep:286
Manual engagement FTW, love my PW, never have that issue!
Just Got it, Give me time!
Old 02-05-2014, 11:12 AM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
Manual engagement is so much better, my 98 cummins work rig has it. I do not like relying on a dial for 4x4 and waiting for the damn thing to lock in a light up, 4x4 low takes forever -.-
My truck locks because I don't have all these fancy auto 4x4 feat like the higher end Rams and GM trucks do. Just 4x4 lock and 4x4 low.
IG:@briley59
Old 02-05-2014, 12:50 PM
Color: gray
Rep:323
wonder if one could order the parts to convert it back to manual and or make/design a kit to do it. to me it would not be to hard. I wish mine was a manual. My other f150 has failed twice when plowing and need me to remove the engagement motor and turn out 4wd low by hand ! sucks when its freeking cold out !
bw 44-44 transfer case, ram 1500 4wd lock
