Old 02-11-2014, 06:58 PM
Adanac Ram's Avatar
Adanac Ram Adanac Ram is offline
Vehicle: 2014 Ram 4x4 CC
Adanac Ram is on a distinguished road
I'll post here as soon as my truck arrives. Hopefully by the end of Feb at the latest.... It's still in Warren.
2014 Ram Sport 4x4 .. Black, Crew Cab, 5.7, 8 speed, 3.92, LSD, Tow, Comfort
2006 Dodge Charger .. PWR 426, 10.93@125.62, 1.52 60', +700DA
Old 02-11-2014, 07:52 PM
TJC.geotech TJC.geotech is offline
Vehicle: 2014 Ram 1500 Crew
Color: Granite
Rep:114
TJC.geotech will become famous soon enoughTJC.geotech will become famous soon enough
Bart, I will concede that there is an awful lot of computer nannyism in these new trucks. There were a number of unexpected reactions to situations that had me scratching my head.
Old 02-12-2014, 01:03 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Color: Burgandy
Rep:160
Originally Posted by TJC.geotech View Post
Ok. ( no comments on the choice of winter wear )
RAM 1500 in 4 Low
So what's the point of this video? He has his truck in 4LO lock and he's idling up a hill. He doesn't have a LSD rear-end and he doesn't have a "TRUE LOCKER" front diff...., looks totally normal to me. From what I understand, unless you have a full- locker front diff, even if you had a FULL-POSI rear diff, which we don't with our trucks, all you really have is a 3 1/2 wheel drive, and even then with the Limited Slip Rear Diff, all you really have is a 2 1/2 wheel drive when it comes down to "high demand" traction scenarios. So I am not quite understanding if this is what the OP is describing as not being locked while only idling or "off the gas". If your front tires are up on the curb with the rear tires on ice, if it's in gear, slipping is slipping, like the video shows, unless it is "low speed" sensitive, unless as "described by one poster the transfer case for "4 LO" wasn't given the correct amount of time to engage. Maybe I'm missing something then.
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ MINI MAX 75 HP TOWING TUNE/ OD TUNE COMING SOON!
Old 02-12-2014, 01:40 PM
Color: Granite
Rep:114
Bartlett was saying that his truck disconnects the transfer case at idle.
Old 02-12-2014, 01:51 PM
DonT DonT is offline
Vehicle: 2015 Ram 3500
Trim Level: Tradesman
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:23
DonT is on a distinguished road
I believe bartlett was saying neither one of the front tires was turning. If it was actually in 4 low, one of them should have been. I think he was suggesting to try 4 low with the wheels turned full lock on a hard surface to see if the driveline binds up. If this is done very much with good tires and some weight on them I would hope the clutches in the transfer case slip before a front axle u-joint breaks. I for one am not willing to find out.
2015 Ram 3500 Crew Cab, Long Box Dually 4x4
2014 Ram 2500 Regular Cab, Long Box, 4x4
Old 02-12-2014, 02:12 PM
Adanac Ram's Avatar
I'm hoping the traction will be the weak link. Not the clutches or the u-joints.
Old 02-12-2014, 02:21 PM
Color: Burgandy
Rep:160
Yeah that is weird why at least one tire wasn't turning up front, and to be more specific, I would hope when 4HI is selected, that the front diff is "NOT" diengaging while my foot is off the pedal at any speed, I understand that would be the case in 4 "AUTO", which I have in my truck also. That theory defeats the purpose of 4 "LOCK" doesn't it?
Old 02-12-2014, 03:20 PM
finn5033's Avatar
finn5033 finn5033 is offline
Vehicle: 2014 Ram 1500 cc 4x4
Trim Level: Outdoorsman
Color: Granite
Rep:32
finn5033 is on a distinguished road
I just read this whole thread and while I admit I am a little confused, I am starting to think my outdoorsman not being available with 4auto was a good thing.
Old 02-12-2014, 08:10 PM
Rep:23
I suspect the front does disconnect at idle and also when decelerating , in 4 auto. When in 4 hi or low lock it does not disengage. The clutch in the transfer may slip if overstressed but in normal conditions it won't. I would rather the clutch slip than break a u-joint or axle. Realistically I don't think this will happen with stock sized tires, but again I am not going to try it on a surface it was not designed to used on.
Old 02-12-2014, 10:02 PM
Color: Burgandy
Rep:160
I did read while surfing for more info, I think it was on Dodge Talk or something, a fellow posted after picking up a 2011 with the same transfer case with 4 auto available, he apparently went to test it for function by turning a tight turn in a parking lot while just idling under good traction, both in auto and 4 lock. He couldn't understand why in 4 lock why the thing wasn't hopping while turning so he asked the sales guy whom had no idea so he dug further and got a different sales rep to call Chrysler Canada and they indicated with the new style of transfer case it is designed to allow slippage in "extreme" scenarios like described rather than "break" something. So DonT's suspicions were probably correct, sooo.... NO, the 44-44 transfer case does not disengage while in 4 Lock while at idle.
bw 44-44 transfer case, ram 1500 4wd lock
