Old 02-05-2014, 01:32 PM
TJC.geotech TJC.geotech is offline
Vehicle: 2014 Ram 1500 Crew
Color: Granite
Rep:114
TJC.geotech will become famous soon enoughTJC.geotech will become famous soon enough
Originally Posted by bartlett View Post
before you say yours dont do that go out and test it ..... the only time the case will engage 4wd is when the gas is pressed ..thats awd not 4wd lock ..
Note this is not the standard 4wd case. that case will do 4wd lock.
I have read your comments and the other comments you linked to, and all I can say is that in my own experience with my own truck, 4 Hi, is definitely engaged 100% of the time. There is no slip or disengagement whatsoever.
Even in 4 Auto, I have not encountered what you are describing, and god knows we have had our fill of ice and snow this winter.
What I could see happening with this type of wet clutch arrangement, is that you could potentially burn the clutch pack with allot of abuse.
Old 02-05-2014, 01:48 PM
Color: Granite
Rep:114
Hang on, is it your truck that is spinning or the truck you were trying to pull???
Old 02-05-2014, 02:09 PM
Adanac Ram's Avatar
Adanac Ram Adanac Ram is offline
Vehicle: 2014 Ram 4x4 CC
Adanac Ram is on a distinguished road
um no ! you might wanna go look at your truck ...if your transfercase has the auto 4wd option you do NOT have 4wd lock ! you only have AWD ...
if you put your truck in 4wd lock it will not be locked into 4wd ! the front will not be locked.
To test this go out and find a parking lot with ice in it and put the front wheels upto the curb ,goto 4wd low lock (wait for the 4wd lock light to come on) let off the brake and the rear tires will spin (if on ice) and the fronts will not ! if you jump on the gas the front will engage. thats AWD not 4wd lock ...
youve been had ! .....
Try it this way...
Put the truck in 4WD Low Lock and drive around the parking lot a couple of times... on the throttle and off the throttle... Then pull up to the curb and let me know what you find.
The Borg Warner 44-44 On Demand t-case should be locked front to rear identical to the 44-45 part-time case in the 1500's (and the 44-46 and 44-47 part-time cases in the HD's) once it is engaged.
2014 Ram Sport 4x4 .. Black, Crew Cab, 5.7, 8 speed, 3.92, LSD, Tow, Comfort
2006 Dodge Charger .. PWR 426, 10.93@125.62, 1.52 60', +700DA
Old 02-05-2014, 03:48 PM
thuffman03 thuffman03 is offline
Vehicle: 2004
Color: Gray
thuffman03 is on a distinguished road
I am so glad I have the manual lever on the floor to engage 4wd!
Old 02-05-2014, 03:56 PM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
Manual engagement is so much better, my 98 cummins work rig has it. I do not like relying on a dial for 4x4 and waiting for the damn thing to lock in a light up, 4x4 low takes forever -.-
My truck locks because I don't have all these fancy auto 4x4 feat like the higher end Rams and GM trucks do. Just 4x4 lock and 4x4 low.
You rely on vacuum actuation. It is not full manual. For full manual you you'll need manual locking hubs. Without the vacuum actuator doing its thing you still have no 4x4 regardless if you tcase is manually selected into 4wd
"I don't care to hear what your ideas are, mine are better"
Old 02-05-2014, 04:29 PM
bartlett bartlett is offline
Vehicle: 2013 Ram quad
Color: gray
Rep:323
bartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the rough
youll find out ... the case will not lock untill you get on the gas..its awd not full lock
simple test : goto 4wd low lock ...drive it alittle so you know its in... put it in park...use a floor jack and jack the rear up slighly. ... get in truck,go to drive,release brake.... whats happening ? oh yea the rear tires are spinning ! if it was a true lock the truck would want to go forward and or rear tires would not be spinning .
Old 02-05-2014, 04:44 PM
Adanac Ram's Avatar
To make sure that I understand...
What happens in that case if you get on the throttle after you release the brake? Everything then locks up?? The same as it would in 4WD Auto???
Old 02-05-2014, 05:05 PM
Color: gray
Rep:323
yep if you get on the gas it will engage. its a on demand/awd system you have not locked . only a clutched engagement. unlike the trucks without the auto option 4wd is locked together inboth 4wd high and low.
The big problem is if you get stuck in thick mud ect you can burn up the 4wd very fast. why? if the front and or rear tires are stuck/not spinning and you gas it the rear or front can spin without the others spinning. there not locked together. at this point the clutches are being over powered and destroying the case.
Old 02-05-2014, 05:29 PM
Adanac Ram's Avatar
Sumbitch... If the 44-44 in my new truck operates as you describe when it arrives, I'm gonna be pizzed. I need the 4WD Auto functionality for winter driving, but I will burn the clutches up in the t-case quickly off-road. Lock needs to be a mechanical (gear or chain) lock... not a clutch/lsd/coupler/etc.
I just found several threads on other forums about the exact thing you are describing.
Thanks for pointing this out. I think.
Old 02-05-2014, 05:32 PM
Color: Granite
Rep:114
This is absolutely not what is happening. If it is on your truck, you need to get it serviced.
And no, I am not putting my truck on a floor jack in 4 Hi to test this. Nor should anyone else.
