Old 02-06-2014, 02:39 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
I have had my truck in some pretty nasty shit. It behaves just like any other 4x4 I have ever had.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 02-06-2014, 03:21 PM
Adanac Ram's Avatar
Adanac Ram Adanac Ram is offline
Vehicle: 2014 Ram 4x4 CC
Adanac Ram is on a distinguished road
I would fully expect it to.
My concern is longevity. Those clutch plates/packs are going to wear over time and when they start to wear, they will start to slip in high-traction situations.
2014 Ram Sport 4x4 .. Black, Crew Cab, 5.7, 8 speed, 3.92, LSD, Tow, Comfort
2006 Dodge Charger .. PWR 426, 10.93@125.62, 1.52 60', +700DA
Old 02-06-2014, 03:22 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:562
Thunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to all
So if you're right then what is the difference between auto and lock on the 44-44? I'm not sure you understand the difference between 4wd and AWD. Full time 4wd is different than AWD. Its starting to sound like the truck in question was getting the wrong signal to the t-case.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread-removed), Matte black Plasti-dipped center console bezel, BT catch can, Corsa 14405 cat back (video).
Old 02-06-2014, 03:26 PM
Adanac Ram's Avatar
I would assume less pressure on the clutches.
Auto / On-demand (AWD)... light pressure.
Lock (4WD)... full pressure (but it's still not truly locked)
Old 02-06-2014, 03:39 PM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
Well if I remember correctly, GM has been running a similar 4x4 system in their trucks since like 01 on certain models and know a few people with the "auto 4x4" option that have had no issue with the logevity and failure of the 4x4 system.
IG:@briley59
Team Bully's Performance
TJC.geotech TJC.geotech is offline
Vehicle: 2014 Ram 1500 Crew
Color: Granite
Rep:114
TJC.geotech will become famous soon enoughTJC.geotech will become famous soon enough
Originally Posted by bartlett View Post
The case in the video is correct..
BW makes about twenty different cases, with about 1/3 of them having the torque sensing clutch and electronics. There's nothing in that video to suggest we are looking at the 44-44.
However despite the absolute lack of technical information on that site, what they do say is that if 4Hi is selected, the clutch is fully locked at all times.
I will agree with you that electrical controls are not ideal in this application, and in fact I have lost 4x4 in an older vehicle from a broken ground wire.
Old 02-06-2014, 03:47 PM
Rep:562
I figured they'd at least have some sort of schematic or description. The whole website is like a sales pitch.
Old 02-06-2014, 04:47 PM
Adanac Ram's Avatar
I don't recall seeing a low-range gearset in the video, so it's not a 44-44 if there isn't one. The video just shows the BW coil and clutch pack functionality that they use in all of their on-demand systems.
Old 02-06-2014, 05:59 PM
DonT DonT is offline
Vehicle: 2015 Ram 3500
Trim Level: Tradesman
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:23
DonT is on a distinguished road
I towed a ram this am and he was just missing a pole so I had him goto 4wd low lock and I would tow him slightly forward and have him give it gas to miss the pole being I could not tow him forward from where he was. So I hooked up and he went to 4wd low lock. I looked back and the rear tires were spinning ! I just told him again to goto low lock. He said it is ! So I looked, it said it was. He gave it alittle gas and the front started spinning. IMO the truck should be locked together and spin one front and one rear unless lsd. Im shocked that this case will not go into lock. Are they all like this ? Mine seems to lock but mine has the older case.
interesting ....
This whole discussion started with the OP saying the driver he was helping put his truck in 4 low lock and that when he gave it gas only the rear tires spun. He then said when the other driver gave it a little gas the front tires started to spin along with the rear. I can't help but think the driver did not give the transfer case time to shift all the way into low lock. It may have still been in 2 hi.
In my truck, it takes several seconds to go into 4 low lock. By the time the OP walked to the other truck to look, it could very well have completed the shift process after the driver stopped applying throttle and the rear tires were coming to a stop. Per the manual it helps the shifting process if the drivetrain is slowly turning and i am sure not in a bind.
In the video, whether that is the exact same transfer case as in our trucks, I don't know. I bet the clutch design is very similar. It looks like the clutch system is designed to be either engaged or disengaged, not in between (slipping). If that is the case I would think there will not be a reliability issue with the system as long as the vehicle is stock or close to stock. If someone were to have much larger than stock tires, or major performance improvements to the engine, then I would be concerned about over-stressing the clutch system and having the clutches wear too soon or even overheat. Otherwise I bet the clutches will last as long or longer than the transmission.
I do know that every time I put my transfer case into 4 lock, whether it is high or low range, it acts just like any 4x4 truck with a part time transfer case that I have ever had, seven jeeps and at least that many 4x4 trucks.
2015 Ram 3500 Crew Cab, Long Box Dually 4x4
2014 Ram 2500 Regular Cab, Long Box, 4x4
Old 02-06-2014, 06:08 PM
Rep:562
DonT, I notice your information says you have a 2014 Lone Star but your sig says it is a reg. cab long box. Which is it? To my knowledge they don't make Lone Stars in reg.cab versions, and if you really do have a reg. cab then you probably have the 44-45 transfer case (which is the reason I'm asking), which could explain the difference.
Btw, your assessment of the t-case not being engaged seems probable.
ETA: Just went to the Ram website and see that they now offer the Lone Star in a reg cab for 2014. To clarify my question then: do you have the 4 or 5 position t-case?
bw 44-44 transfer case, ram 1500 4wd lock
