Old 02-07-2014, 12:01 PM
DonT DonT is offline
Vehicle: 2015 Ram 3500
Trim Level: Tradesman
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:23
DonT is on a distinguished road
Originally Posted by preachp View Post
Hi All,
So what I gather from these two entries is that 4 wheel lock is just that the front and rear axles are locked together. 4 Wheel low is the same as above but in low range tripling the rpm at a given speed, thus the 25 mph warning.
4 Wheel Auto for those who have it, is a limited 4 wheel function in which the rear axle must slip in order for the front to engage. How it does this is really moot.
As for the OP'S statement it is very probably as stated many times, the fact that they did not give the electronics of the transfer case a chance to send an OK to the trucks power train management system thus when the conditions were met the transfer case did it's thing and locked the two axles together.
preachp
Agreed, thanks for copying the information from the manual.
2015 Ram 3500 Crew Cab, Long Box Dually 4x4
2014 Ram 2500 Regular Cab, Long Box, 4x4
Old 02-07-2014, 12:10 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:532
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
Agreed. It's not all wheel drive.
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread).
Old 02-09-2014, 12:24 PM
bartlett bartlett is offline
Vehicle: 2013 Ram quad
Color: gray
Rep:323
bartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the rough
wait till you see this screen . lmaooooo its in 4wd lock and the 4wd is over heated ! lmaoooo um no the clutches are burning up ! locked my azz
Old 02-09-2014, 12:33 PM
TJC.geotech TJC.geotech is offline
Vehicle: 2014 Ram 1500 Crew
Color: Granite
Rep:114
TJC.geotech will become famous soon enoughTJC.geotech will become famous soon enough
Dude, there's something wrong with your truck. I don't know how many other ways to tell you this. Time to see the dealer.
Old 02-09-2014, 12:34 PM
Color: gray
Rep:323
Hey could we get a few test subjects ...
try this it should answer the question ...
go to any open area and put your on demand transfer case (only the trucks that have the auto 4wd option) into 4WD LOW LOCK turn the wheel full right of left lock....now do NOT touch the gas and let off the brake the truck in 4wd low should have plenty of torque to drive on its own power in a circle. if its locked up the truck should start bucking and binding up. if not locked it will drive in a circle fairly smoothly. Now if you touch the gas it should bind up. On demand ..
Try it ...
Old 02-09-2014, 01:07 PM
Adanac Ram's Avatar
Adanac Ram Adanac Ram is offline
Vehicle: 2014 Ram 4x4 CC
Adanac Ram is on a distinguished road
Try it ...
Bart... When you do this, does it then stay locked up if you let off and do it over and over again?? Or does it keep unlocking and then lock up again each time you get on the throttle??
2014 Ram Sport 4x4 .. Black, Crew Cab, 5.7, 8 speed, 3.92, LSD, Tow, Comfort
2006 Dodge Charger .. PWR 426, 10.93@125.62, 1.52 60', +700DA
Old 02-09-2014, 01:26 PM
Color: gray
Rep:323
nope they unlock after gas is dropped. on off on off on off ...
TJC .. NO its not my truck ! I have tested this on two trucks so far. go out and test yours or goto the other site and you will see there is now a 12 page song and dance on that site with MANY people now talking about how theres is the same way. Some have contacted RAM and they claim this is normal and that how it is designed.
Old 02-09-2014, 01:58 PM
Color: Granite
Rep:114
Ok. ( no comments on the choice of winter wear )
RAM 1500 in 4 Low
Old 02-09-2014, 02:09 PM
Rep:532
Try it ...
So you're asking us to go bind our transfer cases to prove your point? No thanks. You do know that it is recommended in the manual to shift the t-case while rolling at low speed with your foot off the gas right? I think that may be part of your "issue".
Thanks for the vid TJC, I have similar pants but they're blue instead of red.
Old 02-09-2014, 02:19 PM
Canadian Hemi Pride's Avatar
stance makes her dance?
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
RAM 1500 in 4 Low
Nice video..
Isn't part of us being Canadian is that we are required to own those pants, and similar style clothing items? Or am I alone on this one...
Tow mirrors up for the haters
