Old 02-09-2014, 03:22 PM
bartlett bartlett is offline
Vehicle: 2013 Ram quad
Color: gray
Rep:323
bartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the rough
that video is perfect, and it is 100% in 4wd without the gas on ...
Now I wonder if this is a programing change from locations ect... The two trucks I tested were 100%not in 4wd with the gas off. and many from the other site says theres were off and some said theres where on ... weird..
any local us trucks wanna test theres ?
Old 02-09-2014, 05:00 PM
Adanac Ram's Avatar
Adanac Ram Adanac Ram is offline
Vehicle: 2014 Ram 4x4 CC
Adanac Ram is on a distinguished road
Originally Posted by TJC.geotech View Post
Nice pants.
Just to confirm... You were stopped... went from 2WD to 4WD Low Lock... never touched the throttle... then idled up the driveway until you lost traction?
2014 Ram Sport 4x4 .. Black, Crew Cab, 5.7, 8 speed, 3.92, LSD, Tow, Comfort
2006 Dodge Charger .. PWR 426, 10.93@125.62, 1.52 60', +700DA
Old 02-09-2014, 07:23 PM
DonT DonT is offline
Vehicle: 2015 Ram 3500
Trim Level: Tradesman
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:23
DonT is on a distinguished road
Ok. ( no comments on the choice of winter wear )
RAM 1500 in 4 Low
The truck in the video works as it is supposed to. One rear and one front tire turning at idle in 4 low. I don't have ice to do this on but I have done it several times on dirt hills and I get the same result every time.
I am not going to do that on a paved surface unless someone is there to donate a new front axle if I break one.
2015 Ram 3500 Crew Cab, Long Box Dually 4x4
2014 Ram 2500 Regular Cab, Long Box, 4x4
Old 02-09-2014, 07:26 PM
Rep:23
Originally Posted by bartlett View Post
wait till you see this screen . lmaooooo its in 4wd lock and the 4wd is over heated ! lmaoooo um no the clutches are burning up ! locked my azz
Where did you find that?
Old 02-09-2014, 08:59 PM
TJC.geotech TJC.geotech is offline
Vehicle: 2014 Ram 1500 Crew
Color: Granite
Rep:114
TJC.geotech will become famous soon enoughTJC.geotech will become famous soon enough
Originally Posted by Adanac Ram View Post
Nice pants.
I tried it in all combinations. 2H > 4L, 4H > 4L, 4Auto > 4L. The truck has to be slightly rolling in Neutral for it to shift to 4L smoothly.
Then idled it up, all the way up the hill twice before I uncovered the ice. The hill is about a 5% grade. In 2H it would just stop at the bottom of the hill and spin.
I will say this, 4L is sooo deeply geared with the 8-speed, I don't know when you would ever use it. And there's allot of backlash through the driveline when the tires do slip.
Old 02-09-2014, 10:06 PM
Adanac Ram's Avatar
Thanks.
Old 02-09-2014, 10:42 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:547
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
Do you not have the LSD rear?
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread-removed), Matte black Plasti-dipped center console bezel, BT catch can, Corsa 14405 cat back.
Old 02-09-2014, 10:51 PM
Color: Granite
Rep:114
Nope. Don't need it for my use.
Old 02-11-2014, 05:03 PM
Liredneck Liredneck is offline
Vehicle: 2009 1500
Trim Level: TRX4
Rep:15
Liredneck is on a distinguished road
Wow that was a huge change in attitude from the first few pages
Old 02-11-2014, 05:37 PM
Color: gray
Rep:323
no change here ....the trucks Ive tested all kick out .. test yours and find out ! so far only one guy has rose to the task.
bw 44-44 transfer case, ram 1500 4wd lock
