Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy
loads with coil springs
. Fits all 2009-15 RAM 1500 including Ecodiesel and 2014-15 RAM 2500!
No modification required
; keep the coil springs. TLC also makes units for 02-13 RAM 2500 & 02-15 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™. Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 02-04-2014, 01:53 PM
bendodge bendodge is offline
Vehicle: 2012 Ram
Rep:163
bendodge has a spectacular aura aboutbendodge has a spectacular aura about
Default TLC bags in MN winter
Pulled my truck out of heated garage and about a hour later when I went for a short drive and noticed a rattle coming from the back of the truck. When I got home I looked under the truck and the air bags had pulled up of the bottom plates. What I think happened is the cold caused the bags to pull up so I pushed on the shrader valve to allow air in and the bags started to come down again. Anyone else have this happen ?
Old 02-04-2014, 02:09 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
How much PSI do have in the bags?
TLC recommends 5 psi minimum without a load. They should be kept inflated to be in contact with the lower platform.
Also, you might try using nitrogen to inflate the bags in the cold.
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 02-04-2014, 02:47 PM
Toon tugr's Avatar
Toon tugr Toon tugr is offline
Vehicle: 2005 cummins & 2010 5.7 Hemi
Trim Level: 2005 & 2010 are SLT
Color: 2010 Silver, 2005 Burgundy / silver
Toon tugr is on a distinguished road
My bags actually pull up into a collapsed state with no air, need to add air to push the bag towards the lower plate.
05 Cummins 4x4 QC SB 112k,10 Hemi 4x4 QC SB 60k
sold 02 http://www.youtube.com/watch?v=i3TkO071kTk
Old 02-04-2014, 11:53 PM
Vehicle: 2012 Ram
Rep:163
I was running 3psi, 5 makes ride rough.
Old 02-06-2014, 11:17 AM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
My truck rides smooth with 10 psi. I am using different tubing than what came with the original kit however. I used sprinkler system tubing from lowes. It is not rigid, you can actually squeeze it together. this eliminates the rough ride at all pressures. You only need to use this tubing from the airbags to the compressor. The tubing from the gauge can be the hard stuff. It cost me $8 for 100 feet of it, and works like a charm!
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 02-06-2014, 08:30 PM
Vehicle: 2012 Ram
Rep:163
What PSI is the hose rated for ?
