Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 02-04-2014, 08:33 PM
joedw00 joedw00 is offline
Vehicle: 2010 Dodge Ram 1500 long bed
Color: True Blue
joedw00 is on a distinguished road
Default Low air blowing out of vents
I just bought a 2010 Ram SLT. I only has 10,000 miles on it. I have noticed that there is not very much air coming out of vents with it on high and recirculation on, I have search the forum and found nothing on it. Has anyone had this trouble?
Old 02-04-2014, 10:54 PM
DarthRam's Avatar
DarthRam DarthRam is offline
Join the Dark Ram Side!
Rep:1543
Do you have the ability to enter a temperature in your controls? If you have it set at a certain temp, say 70, once that temp is reached air will still circulate at a cooler temp since the target temp of 70 has been reached.
If you don't have this ability check the coolant level. If level is good the t-stat or the heater control valve could be shot. You should still be under warranty right? Bring it in after checking what the temp is set at and coolant level.
Old 02-04-2014, 11:22 PM
BigRedRam1500's Avatar
BigRedRam1500 BigRedRam1500 is offline
Vehicle: 2014 Ram 1500
Trim Level: Laramie Longhorn 4x4
Color: Deep Cherry Red & Gold
Rep:58
BigRedRam1500 will become famous soon enough
Make sure it does not have a plugged up cabin air filter, a popular mod for this truck. Also be sure you're not blocking the intake vents on top of the dash at either end... if your running A/C not charged properly coil could be freezing, and also could be fan motor going bad. Hope you figure it out!
Old 02-05-2014, 12:28 AM
Color: True Blue
Thanks for the replies No I don't have the temp setting. Tha coolant is OK. I made a apointment next Tuesday at CarMax where I bought it. If they can't find it I will take it to Dodge, I have Extended Warranty.
