Fox 2.0 shocks - Page 4 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Chassis - Drive Line - Suspension - Wheels and Tires - LEVELING
Old 07-18-2014, 09:24 AM
Geniusgene's Avatar
Geniusgene Geniusgene is offline
Vehicle: 2010 Ram 1500 QC
Color: Inferno red pearl
Geniusgene is on a distinguished road
Originally Posted by theGSE10 View Post
You're spot on, they are definitely pricey but I think they are worth it. I work in construction and have to drive some pretty driving crappy access roads to get to the jobsite sometimes. That's where I noticed the biggest difference between the stock and Fox. Much more controlled and much less bouncing back and forth over bumps.
Would you mind telling me what model shocks your running front and rear. It seems only coil overs are available for 4th gen front ends.
BT catch can, Borla pro xs, Afe drop in filter.
Old 07-18-2014, 09:55 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:418
I assume you mean that you have a 2WD and don't have the coil overs in the front? I have the Fox 2.0's in the rear but I have no idea if they would work up front for you. I'd call them for your application.
800.369.7469
Old 07-18-2014, 10:32 AM
Geniusgene's Avatar
No I have a 4x4 sport. Qc. 2010. All the sites I look at don't have anything but coil overs for the front end. I don't want to change front springs. I'll call. Thanks.
Old 07-18-2014, 12:54 PM
h2oman's Avatar
Rep:418
Oh. Okay. Yeah they only do complete coil overs from what I can see.
Old 07-18-2014, 01:15 PM
Geniusgene's Avatar
Thanks for the info. That's a shame. I don't have the balls to go full coil over on the the fronts because changing spring rates may effect my max care warranty. Off-road warehouse shows them in mono tube for gen 4 ram fronts but until I find someone who has them I'm holding off. Thanks again.
Old 07-18-2014, 01:29 PM
theGSE10's Avatar
theGSE10 theGSE10 is offline
Vehicle: 2013 Ram 1500 4WD Crew Cab
Color: Maximum Steel
Rep:42
theGSE10 is on a distinguished road
Coil-overs are the only option for the front. Would have bought those except I had purchased bilsteins front and rear but then found out the rears were on back order so I went with FOX. I'll eventually upgrade the Bilsteins to the Fox coilovers.
Hellwig SB, Green filter, Borla XR-1, Line-X, BakRollX, JBA TCC Shortys, Raptor 4" nerf, Hunter Bull Bar, Rigid LEDs, Moroso CC, Bilsteins @ 2.8, Fox 2.0 rear, TGC 1.75 spacer, Air Lift 1000, BakBox 2, DS Trinity, LMI mid-tube, 87mm TB
Pics: https://www.dropbox.com/sh/ut4enlwx4fslgd8/slpdRXv6z2
Old 07-18-2014, 01:34 PM
theGSE10's Avatar
Rep:42
You'll actually hear nothing but good things about them but I completely get not wanting to mess with the warranty. I know BDS lift kits come with FOX coil-overs up front so you may be able to get some of the people running them to weigh in.
