03 ram quad cab 4x4 won't go into 4h - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-05-2014, 10:38 AM
bclamz1 bclamz1 is offline
Vehicle: 2003 dodge ram slt 4x4
Color: CHARCOAL GRAY
bclamz1 is on a distinguished road
Default 03 ram quad cab 4x4 won't go into 4h
Guys at a loss, used 4x4 to get out of drive way this morning got rolling put back in 2h. ran into some icy roads tried drop in 4h and no dice it won't go. never done this before suggestions?
Old 02-05-2014, 04:12 PM
AFMEDIC's Avatar
AFMEDIC AFMEDIC is offline
Vehicle: 2002 Dodge Ram
Color: Maroon
Rep:18
AFMEDIC is on a distinguished road
Do you have a manual or electronic shifter?
If Guns kill people, then pencils misspell words and spoons made Rosie O'Donnell fat...
Old 02-05-2014, 05:04 PM
manual
Old 02-06-2014, 09:12 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:518
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
1) Try to shift it while rolling slowly (1-2 mph) and see if that helps.
2) Crawl underneath and see if the shift lever on the transfer case is frozen inside a big chunk of ice/snow.
Old 02-06-2014, 01:31 PM
AFMEDIC's Avatar
Color: Maroon
Rep:18
does the shifter move freely or will it not move? Definitely check to make sure it's not frozen in a block of ice under there. If it moves freely you may have lost the bushing that holds the linkage on the t case, mine is gone and I have a zip tie holding the linkage together (not the most failsafe way to do it but it has held up for a year and a half)
Old 02-06-2014, 01:59 PM
i will give it a look when i get home tonight could not check last nigh 8 inches of snow and ice had to be shoveld
Old 02-07-2014, 08:15 PM
LEW LEW is offline
Vehicle: 2002 Ram 1500 Quadcab 4X4
LEW is on a distinguished road
I have 2002 with manual shift. I had the same problem as AFMEDIC with the bushings failing on the linkage between the shift lever and the transfer case. First the one at the transfer case then the one on the other end. I too have "fixed" them after finding out that just the bushings are NOT available; you have to replace too much for me. It's been probably 3 yrs since the first failure. So far, so good.
Old 02-10-2014, 10:56 AM
WD 40 works wonders on frozen linkage! thanks all
Old 02-11-2014, 08:33 PM
AFMEDIC's Avatar
Color: Maroon
Rep:18
I'm trying to find the link to the party number for the bushing. It is for something else on the truck but it is the identical bushing that they used on the linkage. I'll post the part number as soon as I find it
Old 02-11-2014, 08:41 PM
AFMEDIC's Avatar
Color: Maroon
Rep:18
52105555-AA, "ROD GEAR SHIFT", $18.00
68078974-AA, "GROMMET NONE", $11.42
The top one is the shifter bushing that mopar lists. The bottom one is the same bushing but cheaper. Google the part numbers and you may find them cheaper.
