Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
United Radio
Old 02-05-2014, 02:32 PM
DaSamoan81 DaSamoan81 is offline
Vehicle: 2010 Dodge Ram 1500 CC
Trim Level: st
DaSamoan81 is on a distinguished road
Default 2010 Dodge Ram A/C not working
Took the truck to the dealer and the warranty is up. Im regretting not buying the extended warranty.
Anyway im looking for help on how to tackle the problem. nothing but hot air comes out. never cold.
Truck is a 2010 with 78k miles.
ideas or ways to start trouble shooting would be great.
Freon perhaps? on my way to buy a gauge to check it out
Old 02-05-2014, 04:17 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
If it is low on freon, the compressor should still kick in momentarily. Does the compressor still kick in when you turn it on?
Old 02-05-2014, 07:35 PM
Trim Level: st
when the ac is turned on it kicks in, I hear a click
Old 02-05-2014, 07:59 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Does it stay engaged? If it does check the suction hose coming of the compressor, it will be the larger one. If there's enough refrigerant in there that line will get cold.
Old 02-05-2014, 10:32 PM
Trim Level: st
gauge indicates there's more than enough Freon.
Old 02-06-2014, 10:39 AM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
But does the clutch on the compressor stay engaged and does the suction line get cold. If it does your problem is inside the cab HVAC box, door or something. There was a recall on the HVAC system for 2010 software upgrade or something.
Old 02-08-2014, 09:14 PM
Trim Level: st
suction line is cooler/colder than the other hose line. not freezing cold, just slightly cooler. the compressor stays engaged, I hear it running.
Old 02-08-2014, 09:33 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
I think that the recall had something to do with the limits on door actuation, the control software was changed. Perhaps you have a broken Door. When you cycle between floor, vents and defrost does the airflow move as well to the appropriate locations? Do you have the auto hvac system? Here is a thread on the recall that may help sort out your problem.
http://www.ramforumz.com/showthread.php?t=64515
Old 02-16-2014, 08:40 PM
S77R's Avatar
S77R S77R is offline
Vehicle: 2010 Dodge Ram 4X4
Trim Level: Crew Cab SLT BigHorn
Color: Inferno Red
S77R is on a distinguished road
I had the same problem with mine last spring. Ended up being a leaking Evaporator and they had to pull the whole dash out. Took them about a day and a half to complete. Has been working ever since but now I have a small whistle when I first turn on the AC that no one seems to know what it is.
2010 RAM CrewCab BigHorn 5.7L Hemi - 3.92/LS
18" Boesch Muffler kit - Moroso Catch Can
Old 02-27-2014, 11:06 AM
Trim Level: st
s77r- exactly !According to mechanic theres a leak. Evaporator and condenser will be getting replaced.
