Old 02-05-2014, 05:59 PM
InFocus InFocus is offline
Vehicle: 2011 dodge ram
InFocus is on a distinguished road
Default No fuse issue 2011 ram 5.7l
So my truck got impounded on Saturday
today i went to get it out i didn't have a chance to unplug my amp so i was ready for a dead batt when i got there we towed it to the road and tried to boost it with the tow truck... would not start so we left it on while we reattached my drive shaft then we tried again to start it no dice so the tow truck guy hooked up a 2nd set of cables off his 2nd batt finally the truck turns over and runs fine i let it sit for 10 mins idling b4 i left for home i drove for 30 mins then stopped off at a friends house and left it in the back running for another 20 mins then i drove home when i got home i turned it off and tried to start it nothing click click click... and its flashing No fuse No fuse i checked all my fuses and they all look good so i tried again same thing click click and my wipers started moving with the switch off so now here i am on here
does anyone have any ideas? could my batt just be toast from sitting for 5 days getting drained by my amp and this -20+ weather? or did maybe the tow truck company do something?? or did i just not let it sit long enough to re charge up the batt?
Old 02-05-2014, 06:32 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Battery should be plenty charged. I'm thinking it killed the battery. Try a new battery and see what happens.
Old 02-05-2014, 06:40 PM
ok my dads going to come by later tonight with a volt thingy and a trickle charger to see whats going on... would it matter if the batts been killed a few times b4 this? ive had to boost it about 5-6 times so far because i keep forgetting to turn my amp off (which is now permanently unpluged) this is the longest it sat tho with the amp on killing the batt b4 the next day i would boost it no problems and be on my way
Old 02-05-2014, 10:12 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Your battery is not meant to be totally discharged numerous times. It is not a deep cell battery that is able to be run down to 0 and recharged.
If the battery is less than 10.5 volts it's possibly toast.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 02-10-2014, 03:55 AM
mountie816's Avatar
mountie816 mountie816 is offline
Vehicle: 2015 Power Wagon
Trim Level: Power Wagon
mountie816 is on a distinguished road
It certainly sounds like your battery is toast. One way to test is to disconnect the battery entirely from the truck and then put it on charge. Once it's fully charged(it should read a minimum 12.6 volts on a voltmeter) then leave it overnite(still disconnected) and then check the voltage in the morning. If it's less than 12.6 it's iffy. If it's less than 12 volts it's done and you need a new one. In any event you should invest as in the previous post, a good heavy duty deep cell (AGM) battery i.e Yellow top Optima or similar type. There are many good brands out there. A marine type one would be good as well. I'm sure there are people on this Forum that have had similar experience and can recommend a good replacement for you.
2015 Power Wagon, Black/red decals. Rambox.
Old 02-10-2014, 07:42 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
Battery being dead and you charging as you did will not charge battery back even close to full charge. You need to 4-6 amp charge (slower the better) battery back to full charge, which will be at least 8hrs. Let set for at least 2hrs so surface charge goes down and then load test it. Really only way to check it correctly.
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it's harder if your stupid."
How would you know?
Old 02-11-2014, 01:18 PM
glcarter's Avatar
glcarter glcarter is offline
Vehicle: 2011 Ram 2500
Rep:59
glcarter will become famous soon enough
If you have a amp that big, maybe your neighbors sabotaged your truck!
Just picking brains, mine's worn out!
Old 02-16-2014, 08:51 PM
Clearwaterram Clearwaterram is offline
Vehicle: 2011 ram
Color: Mineral Gray
Clearwaterram is on a distinguished road
Probably a little late for this by now, but you said the temp was -20. With the temp that low, when you drain the battery it will freeze. That will kill the battery. Usually if a battery freezes it will bulge the case. Just a thought.
