Rain water leaking into interior - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram – 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 02-06-2014, 08:50 PM
nancyh1980 nancyh1980 is offline
Vehicle: 2006 Laramie 3500
nancyh1980 is on a distinguished road
Default Rain water leaking into interior
Hi there,
When it rains, water comes through driver and passenger (see attached picture) and headliners near the visors (though not that often).
Even when rain stops, when I drive, water continue to drip until there is not more water.
Lately, when there is water, my interior lights, dashes, radio get possessed. They would come on/off/on/off…even the beeping sound due to open doors. All these while I am driving.
This is 06 3500 Laramie with factory sunroof.
May I know how to take care of this demon?
Thanks for your help.
Old 02-06-2014, 09:27 PM
SShadow1974's Avatar
Vehicle: 2016 Ram 1500 Sport w/RAMBox
Rep:166
First thought would be a leaking sunroof. Second thought would be rear brake light - but I would think it would leak in the back instead (water, like electricity, takes the path of least resistance.)
So, I am going to say it's the sunroof. Take it to an autoglass place and see if they can inspect it.
S S H A D O W
Old 02-06-2014, 09:56 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
^^^ id check here too...
Old 02-06-2014, 09:57 PM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
My brake light leaked on my '06. The seal would get saturated and water would flow on top of the headliner and down the A and B pillar. Easy fix- applied caulking and problem solved. I'd start there first, and then move on to the sunroof... windshield seal... etc. You could also try the smoke test... but difficult to track unless you have a controlled environment. I had a Dakota years ago that leaked and I NEVER found the source.
MODS: Magnaflow Cat-Back Exhaust, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Lund Fender Flares, Aries Stealth Bull Bar, & KC SlimLites.
Old 02-06-2014, 10:21 PM
Rep:3347
Most likely is your sunroof drain tubes are plugged/broken. The headliner needs to dropped and you should be able to see the tubes running forward. You can pull them off and blow out any debris, or if they are broken/cracked then replace them.
Old 02-06-2014, 10:28 PM
hemi4452's Avatar
hemi4452 hemi4452 is offline
Vehicle: 2013 ram crew cab sport
Trim Level: sport
Color: True blue pearl
Rep:77
hemi4452 will become famous soon enough
If it has a sun roof then its the drain lines. My friends jeep just did the same thing
Old 02-09-2014, 06:08 PM
THANK YOU SO MUCH. It was the drain lines. I used chopstick to push through the plastic plugs. Immediately water came out like water gun.
On the passenger side, I made mistake of pushing in too far. The hose came out from the plastic plug. That side took 20 minutes to take fix.
For the 1st time since the 2008, I don't have to park the truck inside when it is raining!
Now another issue. I will post on separate thread.
Old 02-09-2014, 06:28 PM
Rep:166
Glad you got it fixed! Long time to have that problem! Stuff like this is why I read the forums at least once per day.
S S H A D O W
Old 02-09-2014, 09:49 PM
Rep:3347
Glad it's fixed.
I read all my forums 4-5 times a day... but my name is Kurtis... and I'm an addict.
Old 02-09-2014, 10:42 PM
Rep:166
I did say at least once... I'm usually on here 5+ times. LOL
S S H A D O W
