Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 02-06-2014, 09:40 PM
Adanac Ram's Avatar
Adanac Ram Adanac Ram is offline
Vehicle: 2014 Ram 4x4 CC
Adanac Ram is on a distinguished road
Default Preemptive coolant flush to avoid the shtink??
My truck should be here in a few weeks and the reports of the smell from the coolant / hoses / castings has me a little freaked out. If it's as bad as some people say it is, I'll be looking to burn it. Really.
So.... to try and avoid the possibility of having to burn my kewl new truck, would it be worthwhile to do a coolant flush after a couple hours of run time???
Thoughts??
2014 Ram Sport 4x4 .. Black, Crew Cab, 5.7, 8 speed, 3.92, LSD, Tow, Comfort
2006 Dodge Charger .. PWR 426, 10.93@125.62, 1.52 60', +700DA
Old 02-06-2014, 10:04 PM
plumcrazy73's Avatar
plumcrazy73 plumcrazy73 is offline
Vehicle: 2013 Ram 1500 2WD Crew Cab
Trim Level: SLT w/Big Horn EQ GP
Color: True Blue Pearl
Rep:119
plumcrazy73 will become famous soon enoughplumcrazy73 will become famous soon enough
could not hurt, make sure you use distilled water to mix with the anti freeze *which you can only get from the dealer, and it is expensive. do not mix it with any other or tap water.
Old 02-06-2014, 11:06 PM
beeg3 beeg3 is offline
Vehicle: 2014 Ram Bighorn
Trim Level: Bighorn
beeg3 is on a distinguished road
You might be one of the lucky ones that doesn't have the problem. If they just replace the anti-freeze with new anti-freeze that is the same, I'm not sure that it would help. I'm hoping that if it was as simple as that, they would be doing that to all the trucks with the "Smell". It would be a relatively inexpensive fix. Good luck with your truck. Other than this hopefully temporary problem, I have been extremely happy with my truck.
Old 02-07-2014, 01:34 AM
Omac's Avatar
Omac Omac is offline
Vehicle: 2013 RAM 1500
Rep:29
Omac is on a distinguished road
I wouldnt do it. I never had the smell. If you do get a smell you can always get it flushed at the dealer under warranty.
Mopar Hood Deflector, Mopar Mud Flaps Front/Rear, Fire/Ice Mud Flap LEDs, Tonno Bed Cover, Mopar Bed Mat, Mopar Tailgate Liner,Window Tint, Husky WeatherBeater Floor Liner Front/Rear, Mopar Chrome Gas Door
Old 02-09-2014, 06:55 PM
Jayincali's Avatar
Jayincali Jayincali is offline
Vehicle: 2014 Dodge Ram 8 Speed 3.92
Color: Deep Cherry Red Crystal Peral
Rep:95
Jayincali will become famous soon enough
So you can only use anti-freeze from the dealer? Can't just run down to the local auto parts and grab a couple gallons of anti-freeze? I think I might have the issue too as I have a propane smell coming form the vents when turned on.
Old 02-09-2014, 07:44 PM
Rep:119
nope as of now it is dealer only, unless someone knows something I do not
Old 02-09-2014, 08:33 PM
country-boy country-boy is offline
Vehicle: 2014 Ram
Rep:87
country-boy will become famous soon enough
Take a few minutes to read this: http://articles.sae.org/11284/
I don't believe there are any "approved" equivalents, since the formulation is secret (just like Big Mac special sauce). If you want to keep your warranty, play by their rules. I really don't think a pre-emptive flush, even with the right stuff, is going to help. It would be a waste of money, IMHO (at close to $50/gallon, and the system takes 4 gallons).
Old 02-09-2014, 09:22 PM
RAM357's Avatar
RAM357 RAM357 is offline
R A M M S T E I N
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
I wouldn't mess with anything. Right now everything is virginal .. you start messing around, and down the road, need warranty work you may be pooched. Especially if you get the stink and they recognize your work - they could just say you created the problem.
Stand down ..
Var
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau
Old 02-09-2014, 10:09 PM
Adanac Ram's Avatar
Holy carp... $50/gallon??!!??
Stand down ..
Var
Good point. Advice taken.
Old 02-09-2014, 10:17 PM
Rep:119
well actually you need to buy 2 gallons and will have some left over (the dealer stuff has to be mixed, 50/50 ) and even if you pull the radiator hose you will not get all the old stuff out so a bit over a gallon is all you will need. (talking v6) unsure if the hemi holds more or not.
