First real Offroad adventure in my new truck - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Diesel Forums!
Dodge Caliber
Old 02-08-2014, 09:55 AM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
Originally Posted by macc08 View Post
ah princess auto... aka candyland!
ive been meaning to get a hitch just to put in my reciever... *stupid question alert* what size hitch/ball should I get?
Well the most common ball size for trailers is 2.5/16th".. I leave that on my truck at all times so I don't have to go and swap to a 2" ball that is inside my truck. At all times I have a 2 2.5/16th hitches one standard and one inverted (flipped around to position the trailer a little higher) and 1 2" ball. I am going o get an adjustable hitch with both balls on it to make my life easier
I plan to just leave the shackle in most of the time now if I get it.
IG:@briley59
Old 02-08-2014, 10:05 AM
Adanac Ram's Avatar
Adanac Ram Adanac Ram is offline
Vehicle: 2014 Ram 4x4 CC
Adanac Ram is on a distinguished road
Glad you're out and no damage.
Did you figure out why the lights and brakes were going retarded?? There should be a DTC.
Anyway... worst case in your situation would have been that you couldn't find someone to pull you out until the next day .... and you had to leave the truck overnight.... and the temperature dropped about 10* while you were away.... and when you returned the next day, you found your truck solidly frozen in!
Long story... it was a buddy's CJ about 20 years ago.
2014 Ram Sport 4x4 .. Black, Crew Cab, 5.7, 8 speed, 3.92, LSD, Tow, Comfort
2006 Dodge Charger .. PWR 426, 10.93@125.62, 1.52 60', +700DA
Old 02-08-2014, 10:06 AM
bartlett bartlett is offline
Vehicle: 2013 Ram quad
Color: gray
Rep:323
bartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the rough
2" strap wont cut it .... I see them snap all the time..
A good 4" is the best for pickups.. I also like the 30ft's the best. it snaps better and lets the puller get to hard ground.
Old 02-08-2014, 10:17 AM
DonT DonT is offline
Vehicle: 2015 Ram 3500
Trim Level: Tradesman
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:23
DonT is on a distinguished road
Good advice here, I believe. I carry two 4" X 30' straps along with all my other stuff.
2015 Ram 3500 Crew Cab, Long Box Dually 4x4
2014 Ram 2500 Regular Cab, Long Box, 4x4
Old 02-08-2014, 12:33 PM
ksgries ksgries is offline
Vehicle: 2014 Ram 1500 QC
Rep:15
ksgries is on a distinguished road
Originally Posted by DonT View Post
Glad to see you are having fun and learning lessons you won't forget any time soon. At least no one was hurt and no real damage done.
Are you getting a front mount receiver for the winch? Don't forget power cables to go with it, I don't see them in the list. With the removable winch plate you need a way to disconnect the power cables. If you are going to mount the winch in the rear receiver you will need to run long power cables. Make sure the size the cables for load, don't forget to consider the length too. If you run power cables all the way to the rear, they may need to be larger than the manufacturer's recommendations.
Get a couple of sleeves to slide over the synthetic rope if they do not come with the winch. You will need them to protect the winch rope.
What is the rating on the 2" tow strap? it may not be enough for your truck or another truck you may need to help some day.
Have fun and be safe.
Im only going to be using it in the rear. Once I save up another grand ill be getting an iron cross bumper with another Recon winch.
I need to order power cables but im not sure whats best to go with 25" long 6 gauge quick connect?
EDIT: Maybe I should get some 0 or 2 gauge wire and make a quick connect cable myself? probably be cheaper
Where can I get a good sleeve for the rope?
My mistake about the 2" tow strap its 2"x20' it says its rated at 20000 pounds
Should I cancel that and get a wider one?
I got no codes or anything, once I was out of the ice/water/mud everything returned to normal, everything seems good now.
Funny I was actually worried about the water freezing around everything since it was pretty cold.
Its actually 2"x20' rated at 20k pounds. Still no good?
Instagram: @krisgries
Old 02-08-2014, 01:26 PM
Adanac Ram's Avatar
I have a 2"x20' for my car... 3"x30' for my 4x4.
Definitely cancel the 2"x20' order.
Old 02-08-2014, 01:52 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:793
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
Yeah I have a couple 3''x30's. You need something a little bigger for a full size truck, the 2" ones are more for jeeps and lighter vehicles. Make sure you get recovery straps too-they stretch unlike tow straps.
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
Old 02-08-2014, 06:00 PM
Rep:15
hmm alright, ill probably just keep it. I have a few friends that have jeeps, so maybe if they are ever stuck ill just use it for them. It was only $15 anyway and it helped me just make my order eligible for the 16% autoanything discount.
Old 02-08-2014, 06:51 PM
Adanac Ram's Avatar
A good strap will cost you more than $15, but it will save you from a really bad day.
Example of a 3"x30' recovery strap... I just grabbed the first decent one that popped up on Google... I'm sure you can find them a little cheaper if you search.... $67.73 on Amazon...
http://www.amazon.ca/Smittybilt-CC33.../dp/B001CF4UXU
Rep:23
You should likely get 0 gauge and make a quick connect for it. I have bought them on Amazon. If the cable is too small it will cause you to burn up an otherwise good winch. In extreme cases it can burn insulation off the cable and start a fire. I bought 0 gauge cable on Ebay for a reasonable price.
You can find the sleeves in Amazon too.
Cancel the strap if it is not too late. You need at least a 3", 30K strap.
