Old 02-08-2014, 07:22 AM
eightball1971 eightball1971 is offline
Vehicle: 2007 dodge ram 1500 quad
Trim Level: Lone Star Edition
Color: cream white
eightball1971 is on a distinguished road
Default P0441
I have a 2007 4.7L Flex Fuel 1500 Quad Cab. I keep getting a P0441 code I have changed everything associated with the evap. system except for the leak detection valve and the charcoal canister. The only issue I am having is the truck dies when I come to a stop after I get a fill up but never does it again until I fill up again. My question is do I need to change the canister with the leak detection vale or just the LDV valve
Old 02-08-2014, 10:23 AM
Saltillo Express's Avatar
Saltillo Express Saltillo Express is offline
Vehicle: 1998 Dakota RT 178K miles
Saltillo Express is on a distinguished road
Have you crawled under there and looked at it? I've had 2 rams and 1 Dakota throw that old code and each one was just the little hose that connects to the canister gets cracked and leaks. You just trim that inch or so off and re install the hose. It's worth a look anyway.
Also gas cap nice and tight? It'll throw that in a second for a loose or worn gas cap.
Chance
Old 02-08-2014, 10:29 AM
jlc41's Avatar
jlc41 jlc41 is offline
Vehicle: 2013 Ram 1500 CC
Trim Level: Laramie Crew
Color: Western Brown two tone (Hershey Bar)
Rep:39
jlc41 is on a distinguished road
Did you check your gas cap gasket seal? They tend to dry out and cause similar problems.
tint, drop in bed liner, Avs window shades, Raptor bed rails, Dee Zee tail gate damper, Genos cabin air filter, Bak Roll-x cover, Weather tech mud flaps, Recon Xtrem tailgate bar, Moroso catch can, DoMore Slide Step, 5/16 Dual pin stripe, Reese lighted hitch cover, Master lock for hitch receiver, Truxedo bed lites, Hunter SS bull bar, Road Runner embroidered head rests, Plasticolor rear flaps with metal Ram logo, Mopar sill plates.
Old 02-08-2014, 01:11 PM
Color: cream white
I checked the all the hoses connecting to the canister and purge valve did not see any cracks also new gas cap I bought it about a week ago I rest light and this morning it came back on
Old 02-19-2014, 06:49 PM
TooPoorForHemi's Avatar
TooPoorForHemi TooPoorForHemi is offline
Vehicle: 2003 Dodge Ram 1500
TooPoorForHemi is on a distinguished road
Try better gas from different stations. Maybe you're purge solenoid needs to be replaced. Unhook it and drive the truck see if there is a difference. Also run some sea foam through your vacuum lines could be all crudded up.
Old 03-17-2014, 08:23 PM
Pmag Pmag is offline
Vehicle: 2003 dodge ram 1500
Trim Level: Slt
Pmag is on a distinguished road
Leak detection pump, only get it from the dealership, worked for me.
Old 03-21-2014, 06:07 PM
Color: cream white
Leak detection was the solution. Thanks everyone
