Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8
Place your Ad Here!
Old 02-08-2014, 08:21 PM
tommyb6273 tommyb6273 is offline
Vehicle: 1997 ram 1500 4x4
tommyb6273 is on a distinguished road
Default how do i set the fuel sync on my 5.9
I know from what ive read that its turning the dist. but how do I know where to set it?
im getting the p1391 code and I have changed every sensor on the truck and the computer is new. ive changed the pick up in the dist and the crank sensor 2 times each and I still get the code and it runs like the timing is off.
Ive read a couple posts where people had the same issue and it ended up being the fuel sync, but they don't explain how to set it.
Old 02-25-2014, 02:40 AM
major324's Avatar
major324 major324 is offline
Vehicle: 1997 dodge Ram 1500 2WD 5.9
Trim Level: sport
major324 is on a distinguished road
has this been fixed yet??
Old 02-25-2014, 09:42 PM
MF2000's Avatar
MF2000 MF2000 is offline
Vehicle: 2009 Ram Crew Cab
Color: Inferno Red
Rep:13
MF2000 is on a distinguished road
You will need something like a Snap-on scanner. I had a MT-5100 if I remember correctly and a K13A key and it will show a range of +20 down to -20. I found my Dak R/T ran best at zero. A friend of mine said his ran best at +4. You will need to loosen the hold down bolt for the distributor and rotate very slightly. A 1/8" is a big move. When you get it where you want ti, just tighten the hold down bolt down and go drive it like you stole. I mean that....run it up and down the gears various rpms to check for any issues.
Old 06-25-2016, 07:04 PM
rambo90167 rambo90167 is offline
Vehicle: 1996 dodge 1500
rambo90167 is on a distinguished road
mine did that changed all the sensors didn't help found the alternator voltage too low changed it runs like new now
