Trailer Towing with 3.6L - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 02-09-2014, 02:33 PM
Bigbird's Avatar
Bigbird Bigbird is offline
Vehicle: 2017 RAM 1500QC, 8 speed, 3.21
Trim Level: Lone Star
Color: Delmonico Red Pearl
Rep:44
Bigbird is on a distinguished road
Default Trailer Towing with 3.6L
I have a new Winnebago RV trailer on order. The dry weight is 3800 lbs. I am curious if anyone else on this forum also pulls a trailer with a 3.6L and 8 speed tranny. How well does it do?
Old 02-09-2014, 08:48 PM
plumcrazy73's Avatar
plumcrazy73 plumcrazy73 is offline
Vehicle: 2013 Ram 1500 2WD Crew Cab
Trim Level: SLT w/Big Horn EQ GP
Color: True Blue Pearl
Rep:119
plumcrazy73 will become famous soon enoughplumcrazy73 will become famous soon enough
what gears? 2 or 4 wd?
Old 02-10-2014, 12:01 AM
Bigbird's Avatar
Rep:44
2 wd and I don't know what the rear end gear ratio is. I looked on the door frame and it didn't mention anything about this. Where would I find this information?
Old 02-10-2014, 12:41 AM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is online now
Super Moderator
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:883
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
Axle tag. Crawl under that back axle and the tag on the starboard side of the differential will have some bar codes, some other codes, and will either say 3.21 or 3.55. That is the part to pay attention to.
3.55s will give you some more wiggle room with regards to cargo capacity with the trailer hooked up.
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
Old 02-10-2014, 12:54 AM
canadian.bacon's Avatar
canadian.bacon canadian.bacon is offline
Vehicle: 2014 RAM
Color: Deep Cherry Red
Rep:121
canadian.bacon will become famous soon enoughcanadian.bacon will become famous soon enough
rear axle, driver side, if you still have the sticker, you will see the 321 or 355.
if not, you gotta ask for the build sheet, sometimes it is wrong on the window sticker.
check out this thread:
http://www.ramforumz.com/showthread....ght=LSD+number
and post #8 here - http://www.ramforumz.com/showthread.php?t=91589
but even with the 321 you can still tow a lot more than 3800lb, i see you have a 14. Look here too: http://www.ramtrucks.com/en/towing_guide/tow_chart/
Old 02-10-2014, 01:02 AM
Super Moderator
Rep:883
Yeah the window sticker can be wrong, or as in my case it may not be listed at all. What the axle says and what the build sheet says will be the same and will be correct.
Thunderhorse:
Colt:
Old 02-10-2014, 02:00 AM
Strivingfirst Strivingfirst is offline
Vehicle: 2014 Ram 1500
Trim Level: Outdoorsman
Color: Silver/Black
Strivingfirst is on a distinguished road
I just towed 6200lbs for 180 miles with a lot of hills(NW WA state). Considering most of my towing experience came from my 2008 F250 diesel I just sold for my Ram, it did surprisingly well. The 8speed makes a big difference, so I'm not too sure gearing has as much as an impact comparatively. Trailer-brakes, engine-braking and ESC all worked well.
Coincidently, I am planing on doing some Overlanding(stateside) for the next year or two, so the best of luck to you on your journeys.
Dom
Old 02-10-2014, 12:56 PM
sackings19 sackings19 is offline
Vehicle: 2014 RAM 1500
Trim Level: Bighorn
Color: Maximum Steel Metallic
sackings19 is on a distinguished road
Have you seen this head to head review between the Ram 1500 V6 and the new Chevy Silverado V6? They tested a Ram 1500 4x4 crew cab with 3.55 gears with air suspension and Ramboxes. Great review besides getting the Ram's tow rating wrong. They used the 2013 rating. They towed a 6,900 lb trailer and were able to pass going up hill. Anyway, the Ram won out according to the reviewer thanks to the 8 speed and the air suspension.
http://www.fourwheeler.com/vehicle-r...-6-truck-test/
Old 02-10-2014, 03:45 PM
finn5033's Avatar
finn5033 finn5033 is offline
Vehicle: 2013 Ram 1500 cc 4x4
Rep:32
finn5033 is on a distinguished road
Dom
I started a thread like this a while back and didn't get hardly any feedback. Do you have anymore info you can share on your towing trip. Did you reset one of the trip meters for your trip? I am curious as to the kind of mpg you got. I have an outdoorsman V6 on order and will be towing a camper with it. May be pretty close to the weight you pulled. Anything else you can share about the experience would be appreciated. thanks
Old 02-10-2014, 04:48 PM
crabjoe crabjoe is offline
Vehicle: 2014 Ram 3500
Color: Maximum Steel Matallic
Rep:62
crabjoe will become famous soon enough
I don't know how well it will do, but next year, you light duty truck owners might know what these 1/2 can actually tow ... within the SAE's guidelines.
http://news.pickuptrucks.com/2014/02...-for-2015.html
