Trailer Turn/Brake Lights Problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 02-09-2014, 09:05 PM
cshrader cshrader is offline
Vehicle: 2004 Dodge Ram 1500
cshrader is on a distinguished road
Default Trailer Turn/Brake Lights Problem
I recently purchased a 2004 Ram 1500 quad cab. It has the factory installed towing package. When I connect my trailer, all of the lights work except the turn/brake lights (both left and right). I have checked the fuses and checked for power at both the 7 and 4 pin connectors. There is no power at either one. I verified that there is power at the fuses as well.
Any thoughts on what could be wrong?
Old 02-09-2014, 10:35 PM
2014 Ram 2014 Ram is offline
Vehicle: 2014 Dodge Ram Sport
2014 Ram is on a distinguished road
Is there power at both sides of the fuse? there may be power there but does it go through? Also check underneath your bumper for corroded wires or broken or even melted wires, super common with vehicles towing big trailers with lots of light pulling lots of current especially if the trailers light aren't l e d's. start there I'll keep thinking about it and check back and see your progress I'm interested on what's wrong
Old 02-09-2014, 11:06 PM
Thanks for the reply.
I checked the fuses with a meter to make sure they were good so I assumed the power went through the fuse to the other side. I guess I could create a fused jumper to test that assumption.
I looked under the truck and the wires look good as far as I can see. They go into a bundle pretty quick so I can't tell after that.
Old 02-10-2014, 10:15 AM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
Check/clean the contacts on the plug both the trailer side and the truck side. A little contact cleaner and something to scrape the the contacts with, such as a pipe cleaner or tip of a small screwdriver.
Old 02-10-2014, 10:54 PM
All of the trailer lights work fine when connected to another truck so I know that connector isn't a problem.
I can clean the connectors, but they look extremely clean. I doubt they they have ever been used. They look like new.
We are getting freezing rain tonight and tomorrow so it will be a couple of days before I can spend any time troubleshooting this more. I'll let you know what I figure out (if I ever do).
Old 02-11-2014, 08:48 PM
AFMEDIC's Avatar
AFMEDIC AFMEDIC is offline
Vehicle: 2002 Dodge Ram
Color: Maroon
Rep:18
AFMEDIC is on a distinguished road
Check the resistance on the wire from the trailer plug to every connector that the wire goes through along the body. That way you can track down the approximate location of any excessive resistance or open circuit.
If Guns kill people, then pencils misspell words and spoons made Rosie O'Donnell fat...
