5.2 vs. 5.9 for towing - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 02-10-2014, 03:57 PM
bob8040 bob8040 is offline
Vehicle: '99 Ram 1500 2WD
Trim Level: Laramie SLT
Color: red
bob8040 is on a distinguished road
Default 5.2 vs. 5.9 for towing
I drive a '99 Ram 2wd with the 5.2 and pull a 24ft.TT , loaded about 5500lbs. I use an equalizer hitch and sway control and find it a comfortable, controllable tow. I tow with OD off, and definitely avoid any steep grades possible as my set up simply is for flatlands. I am considering a truck that has the 5.9 as well as 4wd. We have run into pretty crappy driving going back north from Texas to Manitoba in March and extra power to deal with those headwinds as well as 4wd would be nice. My 5.2 has been rock solid, and wondering about the rep of the 5.9, and if it is a decent jump in power. Cummins would be sweet but not viable financially at the moment. Thanks for any input.
Old 02-10-2014, 07:42 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
If you don't have one, why not do a transmission cooler. I'd stick with the 5.2. If it's been working, stick with it. I see early 03-04 hemi trucks pretty cheap, now. 345 hp with 3:92 will tow pretty well. My hemi tows better than my friend's early 24V Cummins.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 02-10-2014, 09:25 PM
Color: red
Default 5.2 vs 5.9
I'm running a tranny cooler as I was told a few years back when we got the truck that the tranny in these trucks need to be looked after. My issue is wondering if upgrading to a 5.9 is a good move. Is their reputation as good as the 5.2, which has always acted bulletproof in my experience. Just looking for a bit more towing power. Thanks for the comment, though. Just looking for feedback as I know nothing about the 5.9.
Old 02-11-2014, 08:47 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Personally, I have never driven a 5.2. My 01 5.9 did ok loaded down. I also had 33's with 4.10 gears, so that helps in the grunt department.
Make sure you get 3.92 gears. Or, find an Offroad edition with 4.10's. They also have stiffer springs.
You might crunch the numbers owning a Cummins. I'm paying less money than I did in fuel with my 01 Cummins than I did with my 01 360. Fuel filters every 7500 miles or so are $14. Oil change is about $50 and you can run longer oil change intervals.
Towing mileage will be vastly better. I got about 12-13 highway unloaded with my old truck. Now, I get 13 city with a bunch of idling in these cold temperatures and driving short trips.
Old 02-11-2014, 11:48 PM
Color: red
Thanks for the input, I just might rethink the diesel option.
Old 02-12-2014, 01:16 PM
Rep:326
No problem. Keep in mind, the prices I've said above are if you do the maintenance yourself.
Ultimately, it's your call. I'd try driving both first to see what you like.
Old 03-27-2014, 10:11 PM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
Here in mb you're still looking at about 6,000 difference and most of the diesels are very high mileage.
5.9 magnums are more powerful where it counts over the 5.2 but be mindful of gear ratio's. lots of 3.21 and 3.55, 5.9 trucks
A 3.92 or 4.10 geared 5.2 would pull every bit as well
Silence! Differing opinions will not tolerated
Old 03-27-2014, 11:39 PM
CrazyCanuck's Avatar
CrazyCanuck CrazyCanuck is offline
Vehicle: 2012 RAM1500 Crew 4x4
Trim Level: Outdoorsman
Rep:260
CrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the rough
I would say the 5.9 is just as reliable as the 5.2. On my '97 w/5.9, I had a water pump gasket go at 380,000km, while they fixed that I had them replace the timing chain and gears. That's the only thing that was touched on the motor by the time I sold it with 450,000km. It saw 90% highway miles, and only ever pulled a small trailer though.
2012 RAM Outdoorsman
Factory Mopar Tube Steps, Spray-In Bed Liner.
Added Roll'NLock Tonneau, SwingCase Tool Box, Shattered window puck decal
Old 03-29-2014, 12:09 AM
slimpartywagon's Avatar
slimpartywagon slimpartywagon is offline
Vehicle: 1995 Dodge Ram 1500, 2000 Ram
Trim Level: Laramie, SLT
Color: Blue
Rep:95
slimpartywagon will become famous soon enough
Never owning a 5.2 Ram, I can't compare, but have had great luck pulling with both of my 5.9L Rams. I tow pretty much the same set up as the OP, except I have lots of mountain grades just to leave town. My 1500 does just fine, while my 2500 seams to be lacking in the power department.. I am thinking gear ratios are playing into the equation.
Old 07-25-2014, 09:48 PM
pinstripefan90's Avatar
pinstripefan90 pinstripefan90 is offline
Vehicle: 2012 Ram 1500 4x4
pinstripefan90 is on a distinguished road
I'm a chrysler tech and to be honest there isnt a huge difference between 5.2 and 5.9 gas motors, the biggest thing is gear ratio, I own a 5.2 w 3.55 and it is no power house but it gets the job done, if you had a 5.2 w/ 3.92 you would be pulling easy, let alone if you had a standard trans instead of a weak 46re but at the end of the day gear ratios play a huge part.
- Jake
