Old 02-10-2014, 09:19 PM
shanerocks shanerocks is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Quad Cab
Rep:21
shanerocks is on a distinguished road
Default Factory Hitch Specs
I have a 2012 Ram 1500 QC I have the factory hitch install and am wondering what all the specs are on it. What is the Max trailer weight it can handle. I have all my other specs in order just want the hitch info. Not sure if there is more then one option of hitch that they put on these models. Also how do i tell if its a class III or IV. Thanks
Shane
( . Y . )
Old 02-11-2014, 03:03 PM
CharlieL CharlieL is offline
Vehicle: 2013 Ram 4x4 Crew Cab
Rep:100
CharlieL will become famous soon enoughCharlieL will become famous soon enough
Your questions are a very much 'it depends.' You should have a Class IV hitch on your truck. Most of all the towing info on your truck should be nearly the same as the 2013 info. You can find alot of into at the Ram site; try this link: http://www.ramtrucks.com/en/towing_guide/tow_chart/
Good luck.
Old 02-16-2014, 12:52 PM
CrazyCanuck's Avatar
CrazyCanuck CrazyCanuck is offline
Vehicle: 2012 RAM1500 Crew 4x4
Trim Level: Outdoorsman
Rep:260
CrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the rough
The factory 2" hitch receiver is Class IV. I believe the bumper hitch is rated class III.
From Wikipedia:
According to SAE J684
Class I up to 2,000 pounds (910 kg) light loads
Class II up to 3,500 pounds (1,600 kg) light loads
Class III up to 5,000 pounds (2,300 kg) larger loads (campers, boats, etc.)
Class IV up to 10,000 pounds (4,500 kg) larger loads (campers, boats, etc.)
2012 RAM Outdoorsman
Factory Mopar Tube Steps, Spray-In Bed Liner.
Added Roll'NLock Tonneau, SwingCase Tool Box, Shattered window puck decal
Old 02-16-2014, 06:36 PM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
If the hitch looks like this
then it is a class III.
Old 02-16-2014, 06:44 PM
Rep:21
no its the "full" on mounted to each side of the frame rails. Must be the IV then?
Shane
( . Y . )
