New 1500 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 02-11-2014, 03:05 AM
RAM4ddamore RAM4ddamore is offline
Vehicle: 2013 RAM 1500
Trim Level: STL
Color: parrie
RAM4ddamore is on a distinguished road
Default New 1500
I just purchased a 2013 1500 (v6)
I know it has been painfully cold, but my truck take 15 minutes before it blow hot air from the heater. Is this normal?
Old 02-11-2014, 04:06 PM
Copenhagen Angel's Avatar
Copenhagen Angel Copenhagen Angel is offline
Vehicle: 1999 Dodge Ram 1500
Copenhagen Angel is on a distinguished road
All my Dodge 1500 (v8 but should be the same) have all taken a while to warm up. Does it take 15 min to blow warm air when its just warming up or when your driving? It shouldn't take that long once you start driving it, 5 min at tops. My trucks are older by 14 years than yours but may be the same.
Old 02-11-2014, 04:13 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
my 2007 take a bit. i let it run for about 10-15 minutes this morning and it still wasn't at temp yet. i had to drive a few minutes.
i would say it's normal
welcome to the forum by the way.
be sure to stop by the newbie check in to introduce yourself
Old 02-13-2014, 12:10 AM
ahill37's Avatar
ahill37 ahill37 is offline
Vehicle: 2014 Ram
Trim Level: Bighorn
Rep:19
ahill37 is on a distinguished road
My 2014 Bighorn V6 has the same issue. I traded a 2011 with the 4.7 that warmed up very quickly and would have to turn the heat down after only a few miles. My new one stays on high all the way to work (about 35 miles). I have seen a post on here about the new ones transmissions using a heat exchanger to help them bring the transmission up to temperature quicker for better fuel efficiency. I have seen a picture posted that showed the heat exchanger lines run on the same lines as the heater and if this is the case I could see how the heater would take longer to warm up.
Long post short, my heater also takes to long to warm up.
3 Ram/Dodges, 1 Jeep, 2 Chevy's, I'm sure my wife believes me when I say I need all of them
