Old 02-11-2014, 08:24 AM
tj4ndirish tj4ndirish is offline
Trim Level: Slt
tj4ndirish is on a distinguished road
Default I had a Toyota moment this morning
Ok, so I'm driving into work this morning, it's -3, I'm on a freeway and the car that I'm following decides to go 50 in a 60 mph zone. Better yet, no one in front of him for half a mile and he decides to start hitting his brakes, in the left hand lane. I accelerate to go around him. Once I've passed him I take the pressure off the gas pedal, only to have it stay depressed and next thing you know I'm going 80 and climbing. I jump on the brake and it's still accelerating. I reach down with my foot to try to lift the pedal but my foot won't go under it. I drop it to neutral and the engine revs up to over 5k rpms, so I put it back in gear to keep from damaging the engine. I'm still speeding up and kind of freaking out at this point. I try the reverse and think if I smash the gas pedal again it'll come up, it didn't. I was finally able to get my foot under the pedal and lift it up. It was almost as if it was frozen.
To answer the question going through your head right now, no, the was nothing holding it down, it was simply stuck.
So, my question is, has anyone else had this issue? Could it have been cold weather or just a freak happening?
Old 02-11-2014, 08:33 AM
msmitty's Avatar
msmitty msmitty is offline
Vehicle: 2014 2500 6.4 Hemi 4x4
Trim Level: Tradesman
Color: Maximum Steel
Rep:69
msmitty will become famous soon enough
There was actually just a story about this on one of the auto mag websites dealing with the ram vans (promaster I think?). It basically said any amount of sideways pressure on the gas pedal and they were getting stuck. I'll see if I can find the story.
Old 02-11-2014, 08:40 AM
ccaser's Avatar
ccaser ccaser is offline
Vehicle: 08 Laramie 5.7 4x4
Trim Level: Laramie 1500
Rep:17
ccaser is on a distinguished road
dangerous stuff man, glad you're ok. Maybe get some lube on the pedal mechanism if that was the problem
Old 02-11-2014, 09:45 AM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
WOW......Good thinkg that you stayed calm and eventually released the accelerator......I will be following this thread.....
Old 02-11-2014, 10:33 AM
TJC.geotech TJC.geotech is offline
Vehicle: 2014 Ram 1500 Crew
Color: Granite
Rep:114
TJC.geotech will become famous soon enoughTJC.geotech will become famous soon enough
If this ever happens again, shift to neutral and let the motor bounce off the rev limiter. You will not damage the engine. Shifting to Reverse at 80 would not be good if the tranny would even let you.
Old 02-11-2014, 12:10 PM
Trim Level: Slt
TJC, I didn't drop the tranny in reverse, I meant I did the opposite of letting off the pedal, I mashed it down to see if it would release. I knew if I dropped the tranny in reverse, I'd be picking it up off the road once I came to a stop.
Old 02-11-2014, 01:11 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1230
The trans will not complete the shift, you will break the shift lever before it will let you into any gear other than a forward gear at anything above parking lot speeds. You cant shift to park or reverse at anything higher than like 5mph.
I am curious, arent our newer trucks drive by wire? Meaning they have no physical link (i.e. a cable) between the accelerator and the throttle body? If so this could be any number of things. Start with the pedal assembly, but it could be on the throttle body end or in the PCM. Did it throw a code?
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 02-11-2014, 01:19 PM
Trim Level: Slt
Army.........that was a question I had (not asked) about the drive by wire. I don't know the answer. But, if it had something to do with that system, I wouldn't think that the pedal would stick, it would be at the throttle body where the stick would occur. I'm just speculating of course. When I finally disengaged the pedal you could hear it "pop' for lack of better word. I would assume it's in the pedal assembly. If I can find open space tonight on the way home, I'll try to recreate it.
Old 02-11-2014, 04:12 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:778
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
I have never heard of this happening on a Ram, but I will be mindful of it. Did you get down there and look to see if there was anything it could have caught on?
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
Old 02-11-2014, 04:15 PM
Trim Level: Slt
Thunderhorse, I have not looked to see if it caught on anything. I have some floor mats, but last I looked they weren't near the pedal. I'll look tonight when I get home and post later.
