Old 02-11-2014, 07:45 PM
TJC.geotech TJC.geotech is offline
Vehicle: 2014 Ram 1500 Crew
Color: Granite
Rep:114
TJC.geotech will become famous soon enoughTJC.geotech will become famous soon enough
They are drive by wire.
Old 02-11-2014, 08:01 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:2477
Yes, definitely drive by wire. The pedal sends a signal to the ECM which proportionally commands the throttle body. There is no mechanical connection, it's all done digitally. If the pedal assembly is sticking I would not hesitate to replace it immediately and I would not try and reproduce this at highway speeds. Only puts yourself and others at risk.
sales@revelperformance.com
Old 02-11-2014, 08:39 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
Next time turn off the key. There was a posting on here somewhere about stuck pedals. Asur tested the key off thing, truck is drivable even with electric power steering.
2016 Challenger R/T Hemi 6-speed.
2012 Equinox 2.4...Wife's Ride
2014 RAM 3.6/8 speed/3.55 gears........Gone.
"Life's hard, it's harder if your stupid."
How would you know?
Old 02-12-2014, 10:03 AM
tj4ndirish tj4ndirish is offline
Trim Level: Slt
tj4ndirish is on a distinguished road
Ok, well couldn't reproduce it last night. Didn't really push trying, but just didn't stick.
I will just keep an eye on it for a bit and see if it happens on it's own and keep all these suggestions in mind............specifically to drop it into neutral and turn the engine off. Most importantly, I'll have to make sure not to panic, could be the worst thing I could do.
Thanks everyone for your input, I appreciate it.
Old 02-13-2014, 02:22 PM
CCeastside's Avatar
CCeastside CCeastside is offline
Vehicle: 2010 RAM SLT 4X4
Trim Level: SPORT CREW CAB
CCeastside is on a distinguished road
turn the key off....... should fix it for the moment anyway
Old 02-17-2014, 12:30 PM
2010x3.92 2010x3.92 is offline
Vehicle: 2010 Ram 1500
Color: Inferno Red
Rep:38
2010x3.92 is on a distinguished road
^^^^. Exactly. People freak out when presented with abnormal circumstances. Stay cool turn the key back (it won't go back far enough to lock the steering wheel when it isn't in park). It's way easier and loads safer to assess the situation stopped on the side of the road than traveling at 80mph while over heating the brakes or banging the engine off the rev limiter than slamming it back into gear.
I was annoyed at all the Toyota stuff when people were running into things etc. Turn it off slow it down and pull over, simple huh? I have had throttles stick in drive by cable vehicles too so don't blame that. It's a mechanical/electrical machine it can and will fail at some point.
Be careful and good luck with fixing it!! The bas/abs light came on in my truck last week. That's the most fun I have had since I owned it . Turned out to be a shorted rear wheel speed sensor I found with an ohm meter. No more fun now.
Old 02-27-2014, 01:36 PM
brc3858's Avatar
brc3858 brc3858 is offline
Color: Red/Silver two tone
Rep:33
brc3858 is on a distinguished road
Someone earlier mentioned checking the floor mats. Have you installed any aftermarket mats by chance?
I only ask because shortly after I bought my 2010 I installed some real nice carpet mats, can't remember the brand now unfortunately. But I didn't realize that the new mats were just a little thicker than the factory mat and when the pedal was depressed fully the very bottom edge of the pedal would catch under the edge of the floor mat causing it to "stick". I found out the exact way you did, while passing someone and had to quick pull the pedal back with my foot, not a fun feeling.
The easiest way to check it is to just stand outside the truck and move the pedal with your hand and see if it's close to the mat when depressed fully. It could be that the mat was pulled just a little further forward that day and was just enough to catch the pedal.
Hope that might help!
Old 03-11-2014, 07:34 PM
jagr200 jagr200 is offline
Vehicle: 2010 Quad 1500 SLT 4x4
jagr200 is on a distinguished road
How clean was your floor board? I'd bet anything that it was a small rock that got stuck between the pedal and the slit where it joins. Probably just jammed and fell out soon as you pulled on it.
Old 03-12-2014, 04:05 PM
brucebigham brucebigham is offline
Vehicle: 2014 Dodge Ram
brucebigham is on a distinguished road
I know for sure that the 5.7L is electronic throttle, but not sure about the 4.7L.
HAVE YOU BEEN RAM'D LATELY?
