Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 02-11-2014, 02:44 PM
trojanman22 trojanman22 is offline
Vehicle: 2010 Ram 2500 Laramie Megacab
Engine: 2010-2012 409ci (6.7L) Cummins Turbo Diesel 305hp 610lb/ft (Chassis Cab)
Rep:13
trojanman22 is on a distinguished road
Default H&S Mini Maxx question!
I just bought the programmer from someone that has an 08 6.7L and I have a 2010. When I plug the programmer in it showed his vehicle in the bottom right corner. I went into vehicle select, selected my vehicle, the programmer restarted. Now when I plug it in it shows my vehicle type in the bottom right hand corner. And if I go into the vehicle settings on the tuner it still shows his vehicle info and VIN, etc. If I hit install download or whatever it is on the menu it says "confirming 10-12 dodge cummins". Is it ok to proceed with installing the tune? I've been told it is if it's not "married to the other truck" and I've been told as long as the other person "uninstalled it properly from their vehicle" it's okay. To me, if it's giving me the option to download the tune to my vehicle I should be good but on the other hand I don't want to proceed if I shouldn't. The tuner had the deletes so I've been told not to update it on the site because it'll take the delete software out
Old 02-11-2014, 02:49 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
It's fine to proceed with that. It won't let you install the tuner if it's still married to another truck. The tuner just asks you that to confirm that you have the correct software downloaded for your truck.
Whoever told you not to update it online because it will take the delete software out is wrong. A delete tuner is a delete tuner.... Updating it won't change that. I would definitely download the latest H&S software before you install it on the truck just so you're up to date with everything in case you want to run MCC or OD software down the road.
Old 02-11-2014, 03:17 PM
Rep:13
Oh ok great! Yeah I was told since the govts been shutting a lot of this stuff down I heard if I update it to current firmware that it takes the delete software out of it
Old 02-11-2014, 03:26 PM
Rep:2026
Ya there's been a few guys saying that.... It's gone around on CumminsForum quite a bit as well but it's not true. I've updated my MiniMaxx and it's still a delete tuner. Pretty much everyone on CumminsForum will tell you the same thing.
Old 02-11-2014, 05:53 PM
Rep:13
See I talked to a buddy that took his off his ford when he sold it and went online to change it back to factory and it wouldn't work. He called h&s and they said he would have to send it to them but when they reprogrammed it it would take the deletes off or they would be in trouble with EPA.
Old 02-11-2014, 06:00 PM
Rep:2026
For one, it doesn't make sense to me that he would have to go online to change it back to factory... if he uninstalled it from the truck it should be ready to install on any other vehicle. You just have to load the new file in for the other vehicle.
I'm going to send you a PM with the rest of my reply because I don't want it out on the public forum....
Old 04-19-2014, 01:28 PM
Reaper's Avatar
Reaper Reaper is offline
Reaper is on a distinguished road
I had a dura a before I bought the 14 cummins. I was required to leave the tune on the truck so the engine light would stay off and the derate mode would stay off. Trade in. Is there a way to reuse my xrt pro without h&s reprogramming it and turning it into a street version? It's a race as of now.
09 SLT CC Ram 4X4
And other toys!
Old 04-19-2014, 01:35 PM
Rep:2026
Nope... If you left it installed on the Duramax it's still married to that truck and you're SOL.... It wouldn't work on your 2014 anyways for the record.
Old 04-19-2014, 02:02 PM
Reaper's Avatar
Awesome have me a nice paper weight now. I have been trying to search for things on the 14 and no such luck. Well except eBay exhaust kits from filter.
09 SLT CC Ram 4X4
And other toys!
