Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Recalls and TSB's.
Old 02-12-2014, 08:55 PM
muddy53 muddy53 is offline
Vehicle: 2011 Dodge Ram 5.7L Hemi
Rep:34
muddy53 is on a distinguished road
Default New Chrysler Recall
Just received a New Recall 13V-038.
(The Rear Axle Pinion Nut may loosen due to Undersized Pinion Shaft Splines)
This relates to undersized pinion shaft splines!!
Have to wonder if this was the problem in the first place.
So much for outsourcing the rear Differential! What next.
Chrysler States it could take as little as 5 hours if found defective and possibly more. Will they cover transportation costs?
What Next.
Old 02-12-2014, 09:01 PM
PaulMys PaulMys is offline
Jan 20. Sad Day
Vehicle: no car
Rep:3248
PaulMys has disabled reputation
Does this also include 2012's? (I see you have an '11)
Old 02-12-2014, 09:07 PM
Rep:34
Default 2009 through 2012
My recall states:
2009 through 2012 model year RAM truck (1500 Series) and Dodge Dakota: and 2009 Dodge Durango and Chrysler Aspen Vehicles.
Old 02-12-2014, 09:15 PM
Jan 20. Sad Day
Vehicle: no car
Rep:3248
Ah, thanks muddy. Good to know.
Old 02-12-2014, 09:34 PM
ghorn ghorn is offline
Vehicle: 2012 Ram 4X4 Crew CAb
Trim Level: LoneStar Rambox
Rep:74
ghorn will become famous soon enough
This recall was first mentioned at least 9 months ago, but no parts were available at that time. Several owners had "heard" of it and driven into the dealers who told them to go home, no parts, and maybe not even applicable to their vehicle VIN.
I checked my dealer and he said not to worry due to my own VIN.
It's the lock-nut on the pinion gear which may not have been properly torqued/locked. If you rear axle has a "clunk" when shifting into gear or between reverse/drive.... then get to the dealer. Otherwise, you should wait untill notified.
Old 02-14-2014, 12:42 PM
Rep:34
Default Undersized Pinion Shaft Splines not Pinion Nut!!
Hi Ghorn, Unfortunately, this is an update to the prior mailings. I had the Pinion nut checked.
Now it's (Undersized Pinion Shaft Splines) not loose pinion Nut.
Old 02-14-2014, 12:47 PM
Rep:34
Note this is recall #2 for Pinion Problems.
They are now saying
"The Axil Pinion Nut could Loosen due to the rear Pinion Shaft Splines being Undersized!!" Not a LockTite Problem as thought before!!!
Old 02-17-2014, 11:49 PM
MikeG2012's Avatar
MikeG2012 MikeG2012 is offline
Vehicle: 2012 Dodge Ram
MikeG2012 is on a distinguished road
Chrysler is recalling certain model year 2009-2012 Ram 1500 trucks manufactured from February 27, 2008, through June 30, 2009, and from December 1, 2009, through October 20, 2011; model year 2009-2011 Dodge Dakota trucks manufactured from February 27, 2007, through June 30, 2009, and from December 1, 2009, through September 30, 2011; model year 2009 Chrysler Aspen trucks manufactured from January 3, 2008, through December 18, 2008; and model year 2009 Dodge Durango trucks manufactured from January 3, 2008, through December 18, 2008. The rear axle pinion nut may loosen due to an undersized pinion spline that can allow relative motion between the nut and companion flange.
CONSEQUENCE:
If the rear axle pinion nut loosens, the axle can lock up and cause a loss of vehicle control and/or a vehicle crash with little warning.
REMEDY:
Chrysler will notify owners, and dealers will install a pinion nut retainer, free of charge. The recall began on November 7, 2013. Owners may contact Chrysler at 1-800-247-9753.
NOTES:
This campaign is an expansion of a recall campaign 12V-474. Chrysler's recall campaign number is N08. Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
Mike 2012 express
MikeG2012's Avatar
Double post
Mike 2012 express
