Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 02-13-2014, 01:40 AM
smith2010 smith2010 is offline
Vehicle: 2010 dodge ram
Trim Level: lt
Color: grey
smith2010 is on a distinguished road
Default Blen door problems
I hate to beat a dead horse but I have a 2010 ram that was making loud noise in dash. The heater would only blow out of floor so looked around on the web and found its a blend door. So I replaced the blend door easy and didn't take long well that worked for about two days. Now I cant get heat to the floor only to defrost and vents and back to making loud noise. I took the dash back apart removed actuator and checked gears all are good. reinstalled and lasted one day and back to same old crap. I need some help here so any info will be greatly appreciated sorry to go on and on but is a major thorn in my side
Old 02-26-2014, 02:29 AM
Trim Level: lt
Color: grey
Default Still need help
So I took the first blend door out and ran the truck without if for a couple od days. then bought a blend door from autozone so I am thinking its the quality of the part. I am going to the dealer to get a new blend door hoping this will fix my problem. Thanks for all the lookers but really no input or info to help
Old 03-02-2014, 11:34 AM
BIGDOGD's Avatar
BIGDOGD BIGDOGD is offline
Vehicle: 2009 dodge ram 1500
BIGDOGD is on a distinguished road
I'm having the same problem so i would really like to know how it all turns out. Give us some help guys!!
Old 03-02-2014, 12:24 PM
Slitherbeast Slitherbeast is offline
Vehicle: 2010 Dodge Ram 1500 Laramie
Color: Brilliant Black Pearl Clearcoat
Rep:18
Slitherbeast is on a distinguished road
watch this video. the plastic gears strip and make a knocking sound.
Old 03-05-2014, 02:06 AM
Trim Level: lt
Color: grey
Default problem solved
The motor is easy to change but was giving me fits. So I went to the dealership and got the blend door motor from them. I put the motor in and I have had no more problems so I would not buy this part from autozone because it will not last. Also it was only like ten dollars more at the dealer and you wont have to tear your dash out twice dor the same problem
Old 03-05-2014, 02:12 AM
Rep:2657
Next time i suggest that you purchase your parts through
http://www.heatertreater.net/Ram%2002-08%20Listing.html
the parts from Dodge are cheap plastic & almost brittle,
dodge has had this issue for several years
Old 03-23-2014, 02:57 PM
Ricker69 Ricker69 is offline
Vehicle: 2009 dodge ram sport
Ricker69 is on a distinguished road
ok guys got the clicking noise from center area when vechile is first turned on , clicks for a few minute then stops , replaced the actuator like on the video still doing it , unplugged both actuators and checked again still makes the noise is this the doors then which means taking the dash out to get to it ?
