Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 02-13-2014, 12:18 PM
Rollers888's Avatar
Rollers888 Rollers888 is offline
Vehicle: 2005 Ram 1500 5.7l 4x4
Rep:53
Rollers888 will become famous soon enough
Default Towing Capacity
So at the end of this month I will be moving my wife and all our furniture from Myrtle Beach to Camp Lejeune NC. Its around a 130 mile trip. So not to far. I'm thinking I can fit pretty much all our stuff in a 6x12 Uhaul trailer. But I'm just curious about the towing capacity of my ram. Its an 05' Quad cab. Hemi. 4wd.
This is the trailer and the specs that go with it
http://www.uhaul.com/Reservations/Eq....aspx?model=RV
Old 02-13-2014, 02:18 PM
ajd76's Avatar
ajd76 ajd76 is offline
Vehicle: 2010 Dodge Ram 1500 CC
Trim Level: Sport 4x4
Rep:103
ajd76 will become famous soon enoughajd76 will become famous soon enough
You can email Chrysler (the same way you'd ask for a build sheet) and ask what your rated to tow. I've tried using the documents floating online (bodybuilder I believe), but have run into computer issues opening it. Eventually, I just emailed them, gave my VIN and asked what my max tow rating is. Got an answer the next day.
2010 Ram 1500 SLT, CrewCab, 4WD, 5-Speed Automatic 545RFE Transmission,
5.7L V8 HEMI MDS VVT Engine With 3.55 Axle Ratio and 20" Wheels & Tires:
Gross Trailer Weight = 8400 lbs
Gross Vehicle Weight Rating (GVWR) = 6800 lbs
Payload = 1380 lbs
Curb Weight = 5393 lbs
GAWR Front/Rear = 3900 lbs/3900 lbs
Gross Combination Weight Rating (GCWR) = 14000 lbs
The Ram Body Builder's Guide can be located on the following website: http://www.rambodybuilder.com/year.pdf
Mopar bed rails, Mopar chrome fuel door, Mopar mud flaps, Mopar door sill protectors, Mopar electronic tailgate lock, Ram LL leather shifter, DeeZee tailgate assist, Access tonneau cover, cabin air filter mod, Magnaflow Y-pipe, & Westin Platinum oval nerf bars.
Old 02-13-2014, 02:29 PM
PTCTreeGuy PTCTreeGuy is offline
Vehicle: 2014 Ram 1500
Trim Level: Outdoorsman
Color: True Blue with Black
Rep:34
PTCTreeGuy is on a distinguished road
It's not still inside the driver's door, or is that just a 2500/HD thing? Haven't looked at the sticker on a Ram but it is on my suburban and my dad's Ford
Old 02-13-2014, 02:51 PM
Rep:2625
http://www.rambodybuilder.com/2005sb...cs/dr/mlup.pdf
just in the difference with the short box, the 3.55 & 3.92 geared differentials, there is a 1,000 pound difference
3.55 = 7,600 pound trailer
3.92 = 8,600 pound trailer
if no one has left off the metal tag during a service, you should find it on a bolt that holds the rear cover in place on the rear end
the newer Rams don't have the same tag, they now use a piece of paper that is glued to the axle housing & if you drive where it rains, the tag dissolves & that is one reason i tell owners to send for the Build Sheet
Old 02-13-2014, 05:45 PM
Rollers888's Avatar
Rep:53
Awesome! Thanks guys. From the look of it I will be just fine pulling the trailer considering empty it only ways around 2000lbs. Any tips with pulling trailers? I've only pulled my dads little 7x 4.5 before.
Old 02-13-2014, 08:26 PM
Canadian Hemi Pride's Avatar
stance makes her dance?
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
Double check when merging lanes, don't drive like an A-hole. Always allow space and time to stop in case of an emergency. Double check that all lights are working on the trailer, if it has brakes triple check that they are working before heading on your journey. Check the tire pressure of the truck and trailer before and during the journey. Do not take sharp turns. If you can plan your route ahead of time, make sure to look for the easiest cleanest route. I got stuck downtown in my city with my 04 Hemi 2500 QC long box with a 30footer on a 1 way 3 (narrow) lane street at 430pm, it was hell.
Make sure the 4pin or 7 pin is connected strong, and that the ball is properly secured to trailer and the latch is fully connected with a safety pin on. Cross your chains, it is illegal here to haul and not have your chains crossed. If there is a emergency break away cable on your trailer, make sure the it is also attached to the truck.
Your truck will haul 2000 pounds like it is nothing, I have overloaded my 1500 for the fun of it with some big ass trailers before, and still hauls pretty nice. 10,000 pounds got a bit intense, but it still pulled it along somehow.
Tow mirrors up for the haters
Old 02-13-2014, 08:31 PM
Rollers888's Avatar
Rep:53
Thank you very much for the info man. Is it recommended to lower the psi in the rear tires at all?
Old 02-13-2014, 11:17 PM
noclass's Avatar
noclass noclass is offline
Vehicle: 13 1500
Color: True blue
noclass is on a distinguished road
Make sure your tires are rated for it
Old 02-14-2014, 01:14 AM
Trim Level: SXT 4x4
Rep:2802
As Noclass said, make sure you have proper load rated tires for the driving. The tires on our work trucks we don't air down for hauling RV's, and I have never aired mine down. Airing down would be more for towing on sand. Airing down on a long haul will cause the sidewalls to flex and wear the tires excessively.
Old 02-14-2014, 01:24 AM
dodgeboy360's Avatar
Vehicle: 2015 Dodge Ram
Color: Granite
Rep:505
Hook up and forget about it.. Just be smart when your driving.. I've had 12'000lbs behind my 2012 1500 pulled pretty decent
Trailer tow package, husky liners, timbrens, more to come
