Towing Capacity - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 02-14-2014, 01:51 AM
dodgeboy360's Avatar
Vehicle: 2015 Dodge Ram
Color: Granite
Rep:505
the brake controller wouldn't have helped in the case of the MTO.. The truck itself is a 1/2 ton. When passed the weight load there are some big tickets, because technically you are putting yourself and everyone else at danger.
I know it wasent the smartest thing to do.. I'm waiting for someone to chew my ******* out about it.. But like I said I've hauled many loads of wood and many loads of anything else just have to be smart about it
2015 Ram 1500 crew cab 4x4 Hemi
Trailer tow package, timbrens, husky liners, k&n drop in, roll up cover, 14" magnaflow w/4" stainless tip, LED bedlights, led reverse pods, 2" HBS, Bfg KO2
Old 02-14-2014, 01:54 AM
Color: Granite
Rep:505
Sorry to the OP we kinda went off the rails a little bit on your thread but it's still has to do with towing so maybe it will help
Old 02-14-2014, 02:07 AM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
atleast they were short drives for the most parts.
These trucks do haul amazing...
Here is my work 2500 Hemi RWD. either 27 or 29Foot trailer.
And mine sitting pretty after some hauls.
30 footer, with 3 slide outs, pretty heavy.
30 foot Cargo trailer/Car hauler. I got a little out of hand with the filters
IG:@briley59
Old 02-14-2014, 11:11 AM
Rollers888's Avatar
Rollers888 Rollers888 is offline
Vehicle: 2005 Ram 1500 5.7l 4x4
Rep:53
Rollers888 will become famous soon enough
No worries on getting off topic on my end. I got the info I needed. Now i'm just enjoying reading your post!
Old 02-14-2014, 02:00 PM
Trim Level: SXT 4x4
Rep:2826
atleast we throw in some pics too. These trucks haul great. My work 04 2500 hauls smoother then our 08 F350 4x4 with a load for sure. With the size of the trailer and the weight of it you got back there, you will have no problem towing it. Might also be a good idea to make sure all tires of truck and trailer are torqued correctly. You never know with Uhaul sometimes .
Having the tires on truck and trailer at proper pressure, will help with the milage a lot. Low tire pressure will cause resistance and pull. I always keep a tire pressure gauge on me. When you stop for gas or washroom break, just give a quick double check.
Maybe grab a little portable plug in air compressor from Walmart or where ever to keep in the truck for if there is a problem. Will also be handy in the future too.
IG:@briley59
Old 02-15-2014, 08:49 PM
Rammers Rammers is offline
Trim Level: slt big horn
Rammers is on a distinguished road
enjoy you're trip. I have a 2010 crew cab 4x4 with hemi. I pull a 7x14 enclosed trailer that weighs about 5000lbs with my load but it does have brakes on both axles which is a bonus. pulling isn't a problem at all. the wall being pulled behind my truck(enclosed trailer) is tough on miles per gallon though...
Old 02-16-2014, 11:38 AM
AFMEDIC's Avatar
AFMEDIC AFMEDIC is offline
Vehicle: 2002 Dodge Ram
Color: Maroon
Rep:18
AFMEDIC is on a distinguished road
i pulled almost 10,000 lbs helping someone move with my 2002 4.7 and it didn't skip a beat! these trucks are awesome!
If Guns kill people, then pencils misspell words and spoons made Rosie O'Donnell fat...
Old 02-18-2014, 05:35 PM
JAWS37 JAWS37 is offline
Vehicle: 2004 Dodge Ram 2500 CTD
JAWS37 is on a distinguished road
I tow a 26' boat on a dual axle trailer. Make sure you have a spare tire for the trailer, check the tires for proper air pressure and that there are no cracks in the sidewalls. Don't just rely on seeing that there is tread as trailer tires wear our long before the tread wears out. I change my tires every 5 years on the trailer, check the tire manufacture date on the sidewall to see when the tire was manufactured. I have seen lots of Uhauls on the side of the road with issues related to tires or for other reasons.
Tire failure occurs often when you go too fast, tires are usually rated for 65 mph and below, speed will kill a tire real fast.
On this trip I was pushing the limit on age, I had one tire blow about 30 minutes into our trip and 2 others have radial separation failure.
Old 02-26-2014, 10:40 PM
Rollers888's Avatar
Rep:53
At least nothing happened to that beauty of a boat!
Old 02-27-2014, 10:52 AM
Or the trailer.
